Hey! Do you have any suggestions on the following build? I'm looking to upgrade a really old system (4yrs old). I want a system thats biased towards gaming... I'm especially interested in running Oblivion. Are all the following components compatible? I live in the UK so any prices quoted are in GBP (English pounds)
1. CPU: AMD AM2 Athlon 64 4600+ Windsor Core, Dual Core 2.4GHz, 512KB x 2 Cache, Retail
(need some suggestions here, dunno whether to go with this one or downgrade to the 4200+ and save 30 pounds or even the 3800+ and save 60 pounds)
2. ASUS M2N32-SLi Deluxe NF590 SLI, Socket AM2, PCI-E(x16), DDR2 800, SATA II, SATA RAID, ATX, Wireless
(Need help again! Whats the advantage of a NF590 board over a NF570? Im really confused here... Wanted this board for future compatibility and the opportunity to double up the graphics card)
3. 512Mb Gainward 7900GT, PCI-E (x16), Mem 1400 MHz, GPU 550 MHz, 24 Pipes, Dual DVI-I/S-Video
(Wanted to spend a good chunk of budget on graphics card... is this a good option? Will this provide me with the possibility of doubling up in the future?)
4. 1GB Corsair XMS2, DDR2 PC6400 (800), 240 Pin, Non-ECC Unbuffered, CAS 5-5-5-12
(Dont think i can afford 2GB with current specs... Is this ram compatible? Is it alright to have only one RAM chip? Might save up and buy a further 1gb in future... Is this ram compatible with motherboard?)
From now on i was trying to go for cheap options... Dunno if they are any good...
5. 80 Gb Samsung HD080HJ SpinPoint P80, SATA300, 7200 rpm, 8MB Cache, NCQ, 8.9 ms
(Dont really use that much HD space)
6. 550W Xclio X14S4P3 Modular SLi U-Quiet 14cm Fan 87%+ Efficiency Trio+12v EPS 4SATA PCI-E
(Dont really know that much about PSUs... will this provide enough power and be silent enough???)
Also... a few more questions....
i've been reading about 65nm processors being released in December... Will this system be compatible with them?
Sorry to bombard you guys with so many questions!
I'm not extremely computer literate so need all the help i can get!
Thanks!
Mike
Thanks!
Mike
