Archived from groups: comp.dcom.videoconf (More info?)
We are having major problems establishing IP videoconference on a
Tandberg 800 system. We can NetMeeting to<>from external but cannot
establish an IP call to a 'real' videoconferencing system.
Firewall is SEF - rules appear to have been setup apropriately - call
arrives on the Tandberg but does not get back out through the
Firewall. NAT is in use at the Firewall but not on the Tandberg itself
- allowing the Firewall to handle this.
Is there anyone out there who has had a similar problem with this
combination? We have even opened up the Firewall rules for the
Tandberg (temporarily) but still cannot communicate.
I have emailed Tandberg but as yet have had no response.
LC,
Tandberg tech support is usually pathetic and very arrogant.
What ports did you open and what firewall rules did you set?
Also what is 'Firewall SEF', which brand of firewall are you using.
RS
>ISDN works fine.
>I would welcome any advice....
>Thanks in advance.
>LC
Hi RS
SEF = Symantec EnterPrise FireWall
The specific Inbound and Outbound rules are as follows:
Rule ID: xx
Description: VC Inbound
Access Mode:
Allow Services: H245 h323 h323* telnet*
Service Limits: telnet h323 5555-5560/udp 1720/tcp
Proxy Limits: ftp-disallow-gets:0 ftp-disallow-puts:0
Advanced Services:
Application Scanning: 1
In Via: int-external
Out Via: int-internal.new
Source: Universe*
Destination: host-tandburg-n.n.n.n
Time: Authentication: User: User: Group: Group: Alert 5 minutes
threshold: Alert 15 minutes threshold: Alert Hour threshold: Alert
Day threshold: Alert Week threshold: Log Normal Activity:
1 Application Data Scanning: 1
Rule ID: xx
Description: VC Outbound
Access Mode:
Allow Services: H245 h323 h323* VC_UDP
Service Limits: h323 5555-5560/udp 1720/tcp 2326-2375/udp
Advanced Services:
In Via: int-internal.new
Out Via: int-external
Source: host-tandburg-n.n.n.n
Destination: Universe* Time: Authentication: User: User: Group:
Group: Alert 5 minutes threshold: Alert 15 minutes threshold:
Alert Hour threshold: Alert Day threshold: Alert Week threshold:
Log Normal Activity: 1 Application Data Scanning: 1
We were also advised by Symantec to disable the H323 proxy...
Does this enlighten any?
Thanks
LC
ArthurLange <artielange@cox.net> wrote in message news:<fit0909nlj5kt363ugepbmavfg2ifg7u9g@4ax.com>...
> LC,
> RS
Just about every video conferencing system on the market uses different
layer 4 ports. Most H323 aware firewalls are behind in the stack versions
being used by the popular VTC systems on the market
Tandberg has a document that will specify ports etc. to open. Ask them for
it.
"LC" <lesley.chaddock@biwater.com> wrote in message
news:5e3eba6.0404270744.50691a3f@posting.google.com...
> ISDN works fine.
> Thanks in advance.
> LC
Sounds to me like you need another solution. We use and reccommend a
software solution that is literally plug and play. have a look at
www.whisperit.com/emeetings
