I am building a portible "Gaming Server". I have just picked up an Opteron 146, and now I am trying to find a good mobo to match.
I know I need SATA II and PCI 16x (Since the HD I bought for it is a SATA II, and the videocard is an eVGA 7600GT.) So I have narrowed the field to three contenders:
eVGA 131-K8-NF44-AX
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110769&Category_Code=AMD939
GigaByte GA-K8N51GMF-9
http://tw.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ProductID=1939
Asus A8N-VM
http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110645&Category_Code=AMD939
Any idead which one would be best? Or is there a better option for my needs?
I list these three because I have used products in the past from Asus, eVGA, and Gigabyte. They are all quality vendors. I know MSI makes a mATX 939 SATA II/PCI 16x mobo, but I have had nothing but trouble with thier mobos. And, don't even mention ECS.
Any help or suggestions would be greatly appriciated.
And, it has to be an mATX mobo, as it is going into a X-Qpack Case.
eVGA 131-K8-NF44-AX
Asus A8N-VM
