Tom's Hardware > Forum > Computer Peripherals > Other Peripherals > Joystick/DirectX8 Problem
Forum Computer Peripherals : Other Peripherals - Joystick/DirectX8 Problem
I'm currently experiencing a huge joystick problem with Win 98SE. I used to have a steering wheel plugged into my soundcard gameport and it worked properly. I wanted to use my Microsoft Sidewinder joystick with a new game, but I noticed after I installed the software for it that the joystick icon in the control panel has disappeared. Now I can't use anything! I ran the DirectX8 diagnostics and it said that I was missing a file called joy.cpl. I've re-installed DirectX8 twice now, but it won't add the file I need. Device Manager said that the gameport was working properly. I think the problem started to occur right after I disconnected the wheel. I desperately need help! Thanks for reading,
Sponsored Links
I would suggest uninstalling all your joystick drivers and re-installing them. Also try re-installing your sound card driver--an updated driver may be available. I have a soundblaster Live Card and the joy.cpl driver was installed with its driver.
Also, consider installing Directx 8.1--yea I know.
<i>Speed doesn't kill,</i> <b>lag does.</b> :cool: James
Reply to ravenprime
joy.cpl is the file in the windows system for access the control panel for joysticks. You can safely copy it from someone elses machine. It is in C:\windows\system.
If you can't find it, let me know and I can E-mail a copy to you
<A HREF="http://www.anandtech.com/myanandtech.html?member=87962" target="_new">My Rigs </A>
Reply to BGates2B
There are 1222 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
