Archived from groups: microsoft.public.win2000.advanced_server (
More info?)
Hi Neil
It is possible by providing a domain account credentials to connect to the share from the XP Home PC.
Username: Domain\login ID
Password: <password>
An example of the Username could be if the domain was "microsoft" and the login name was "neil": microsoft\neil
Additionally you could map a drive to the share, and specify to "Connect Using a different Name" and supply the domain account login.
Obviously, you have to set the Share permissions and the NTFS file permissions on the resources you are trying to access, to allow the
user account to connect.
How to configure file sharing in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;304040
Hope this helps.
Best Regards,
Darren Curtis, MCSE
Microsoft Enterprise Support Engineer
Get Secure! - www.microsoft.com/security
When responding to posts, please "Reply to Group" via
your newsreader so that others may learn and benefit
from your issue.
This posting is provided "AS IS" with no warranties, and confers no rights.
