Hi geeks and experts,
I am going to order a new rig powered by E6400. Mid-range budget. I will be flight simming and doing some engineering simulations on this. I have a couple questions regarding which mobo might work the best for the money. (I want to retain the SLI capability because I sinerely believe nVidia cards have better performance per buck than ATI cards)
I am considering:
1) last generation Asus P5ND2-SLI with nForce 4 SLI, which is cheap ($86.99 at Newegg) and avaliable (Asus said it supports Conroe, maybe with new BIOS); and
2) newer Asus P5N-SLI with n570, which would be about 30% more expensive (expected >$110) and god knows when they will be avaliable.
I checked the nVidia comparison chart and couldn't really find too much difference between n4 and n570 performance wise. I am thinking of using at best 7900GT, for which the 8x SLI should not be a bottleneck. I expect to only mildly OC up to about E6600 level (if I get a non-retail and have to buy a Zalman fan, I guess I will clock more).
So, does it worth it to "wait" and "pay" for the new n570 board? or would the n4 board performance just as well with not much difference?
This is my first question post, thank you very much!
Eric
side question:
would DDR2-800 RAM work with DDR2-667 boards? just in case my next mobo could use it. I don't mind slower timings with the -800 RAM.
I am considering:
Eric
side question:
