X6800 getting warning low voltage - help!
redraider_gamer
135
My new X6800 seems to be working great, well, until I installed the Intel system utility monitor. Temp is grat. fan is great. CPU voltage is supposed to be 2.05v. I'm getting fluctuation from 1.141v to 1.785v. The intel utility pops up warning all the time. I sent a note to Ultra who replied that this was normal. Is this normal?
Conroe X6800
Intel D975XBXLRK 304
2 GB Corsair Pro PC6400
74 GB 10k raptor HD
ATI X1900XTX Vid
Ultra 600W Xfinity ult-31848
Soundblaster Audigy 2 SZ
Thermaltake Big typhoon CPU Fan
Help...
if you have speedstep enabled sure. You can probably disable the warning messages in the program.
As long as your system isn't locking up i wouldn't worry to much about it.
Conroe X6800
74 GB 10k raptor HD
ATI X1900XTX Vid
Help...
redraider_gamer
135
Thanks, your reply about speedstep got me looking at Intel's specs. It the utility that's the issue. It's not ready for Conroe. The X6800 runs at 1.150v at idle, not at the Prescott settings around 2.05v. The utility is giving bogus warnings based on bad data.
Thanks again.
pentz0r
30
Thanks again.
Prescotts don't ran at such high voltage... generally 1.388v - 1.412v
C2D X6800 with SpeedStep enabled should ran at 0.9v iddle and 1.2v full load according to Toms Hardware tests
1Tanker
Splendid
Apr 28, 2006
4,645
Thanks again.
C2D X6800 with SpeedStep enabled should ran at 0.9v iddle and 1.2v full load according to Toms Hardware testsYeah, Intel CPU's haven't required 2.0v since Mendocino core(<533 Celerons, and PII's).
