Archived from groups: microsoft.public.pocketpc (More info?)
"Sarah Tanembaum" <sarahtanembaum@yahoo.com> wrote in message
news:32r3frF3o5rs5U1@individual.net...
> Even at max, its too low. How do I increase it further? Is there setting I
> can use? Thanks
Headphones?
But do make sure that both the app volume AND the device speaker volume is
up - probably the case but wanted to at least mention it.
>>can use? Thanks
> Headphones? >
Hi xTenn, if what you refering app volume is Windows Media Player
volume, then its yes, but what it the device speaker volume? Where do I
set up for that? Thanks.
Reply to message from Sarah Tanembaum <
ST> Hi xTenn, if what you refering app volume is Windows Media Player
ST> volume, then its yes, but what it the device speaker volume? Where do
ST> I set up for that? Thanks.
ST> Just a reminder, I'm using HP iPAQ h1935
I was under the impression that the h1935 was current enough to have the
speaker icon at the top of the screen - tapping this would normally give
you the master volume, if you will. I'll verify, since it might not be the
case after all.
"xTenn" <xtennremovethispart@tds.net> wrote in message
news:1103736158@xtennremovethispart.tds.net...
> case after all.
Also, I once had a pair of behind the ear sport headphones that apparently
required a lot of power to drive them. I switched to a different set and it
worked great. This is rare and doubtful your problem, but it happened to
me.
> case after all.
Duh...
You are absolutely correct. I've look everywhere but there ...
Thanks again.
