I’m making my first build in a few years and would greatly appreciate your help. I’m currently on an Athlon 1800+ with 768MB RAM and an Radeon 9600XT (128MB) video card. That machine has served me well but it is time for a new one! Here is what I plan on using the computer for:
80% Online gaming on Everquest – This is the ONLY game I will be playing. I will be playing 1 character on M-F and would like to run as many as 4 sessions (aka 4 boxing) on the weekends.
20% Internet browsing, MS Office, email, etc.
Here are some assumptions I would like to make:
1) I have approximately $2,000 USD to spend.
2) I’d like to be up and running by mid to late August.
3) I do not need a keyboard or mouse. I also have a Dell 1905FP monitor, which I feel is getting the job done (is it HDCP certified?).
4) I am not a hardcore overclocker. Since this is going to be such a huge upgrade, I’m sure stock settings will probably blow me away.
5) The desk is in my living room and I often have my TV on across the room. I’d like to avoid components that are known for being particularly noisy so I don’t have to jack up the volume on my TV.
6) I would like to somewhat future proof the system so that it will last for at least 2 years. I am not interested in upgrading another part 6 months down the road. I will probably run XP Pro for two more years.
I’ve been doing a ton of research and I’m fairly certain I want to go with an Intel Conroe. More specifically, I’m pretty sure I want the E6600. After that, things get very fuzzy so that is why I am requesting your help with my build:
Edit 8/6/6 Okay, I did some thinking over night and am thinking I may have selected components slighty stronger than I need.
Replaced P180 & Seasonic S12-600W with P150 w/430 Antec NeoHE
Removed 'Cooling' since I'm sure I'll use retail fan.
Replaced Intel D975XBX ‘Bad Axe’ r304 with Intel BOXDP965LTCK Socket T (LGA 775) Intel P965 Express.
Replaced eVGA Geforce 7950x2 1GB with eVGA Geforce 7900GT KO 512MB .
Replaced Pioneer Black 111D with NEC ND-3550A Silver.
CPU – Intel Core 2 Duo E6600 Retail
$340
Case – Antec P150 -- Thoughts?
http://www.newegg.com/Product/Product.asp?Item=N82E16811129166
$140
PSU – Antec NeoHE 430 ATX12V 430W -- From what I've researched, 430W should be enough to power this system.
http://www.newegg.com/Product/Product.asp?Item=N82E16817103940
$0 (included with case)
Thermal Compound – Arctic Silver 5
http://www.newegg.com/Product/Product.asp?Item=N82E16835100007
$6
MB – Intel BOXDP965LTCK Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail
-- I don’t really need SLI or Crossfire and I’m not a hardcore overclocker. I’m probably going to use onboard sound for now. What features am I going to lose by going from the 'Bad Axe' to this?
http://www.newegg.com/Product/Product.asp?Item=N82E16813121035
$107
GPU – eVGA 512-P2-N568-AR Geforce 7900GT KO 512MB 256-bit GDDR3 PCI Express x16 Video Card - Retail
-- I know I want eVGA and 512MB so this narrows it down. Thoughts?
http://www.newegg.com/Product/Product.asp?Item=N82E16814130034
$360
RAM – G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 533 (PC2 4200) -- Will run 1:1 if I don’t overclock. Thoughts?
http://www.newegg.com/Product/Product.asp?Item=N82E16820231018
$150
HDDs – I’m pretty sure I want to get a 10,000RPM drive for my OS and game. Then a nice 7,200RPM for storage. I am slightly concerned about noise.
Western Digital Raptor WD740ADFD 74GB 10,000 RPM 16MB Cache Serial ATA150 Hard Drive – OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16822136033
$170
Seagate Barracuda 7200.10 320GB
http://www.newegg.com/Product/Product.asp?Item=N82E16822148140
$95
DVD/RW – NEC ND-3550A Silver
http://www.newegg.com/Product/Product.asp?Item=N82E16827152060
$30
Stuff I’ll probably get later:
LCD -- UltraSharp 2007FPW if the budget allows. If not, I’ll add later.
SC – How much CPU power do you really save by getting a sound card? Everquest does not have amazing sounds so I’m tempted to go with onboard audio. X-Fi probably... Thoughts?
TV Tuner – Hauppauge WINTV-PVR-150 PCI -- Convert from VHS to DVD and watch TV in a window.
Speakers – ?
3.5/reader – MITSUMI Black 1.44MB 3.5" Internal USB 2.0 digital card reader with Floppy Drive Model FA404M BLK - OEM
UPS – I think it is time to finally buy one. OPTI-UPS Enhanced Series ES1000C 1000VA 700W had pretty good reviews.
Is there any stuff I’ve left out? Thanks in advance for all of your opinions, advice, and help!
$340
$140
$6
$107
$360
$150
$170
$95
$30
Speakers – ?
