Tom's Hardware > Forum > General Networking > WAN/LAN > Problem and solution for the D-link dvc-1100 (dvc-1000) wi..
Forum General Networking : WAN/LAN - Problem and solution for the D-link dvc-1100 (dvc-1000) wi..
Archived from groups: comp.dcom.videoconf (More info?)
In case this can help someone else avoid the pain I just went through with
this videophone see my problem/solution below or at this website:
http://myweb.cableone.net/jimjoh/dvc1100wrt54g.htm
WRT54G Problem and Solution
As far as networking products go, this camera is easy to setup, unless you
have a Linksys WRT54G. If you place a call from behind the wrt54g the
remote side can't see you (i.e. you've only got video working in one
direction). From taking some packet captures it appears that the wrt54g is
changing the destination ports on outbound traffic! It changes to a port
that still in the valid range (udp 15328-15333), but it's changed
nonetheless. I believe this is the cause of the problem.
Everything works fine as long as the initial call is from a non-wrt54g
router. The wrt54g can receive calls just fine. In fact, once the wrt54g
receives a video call you can then initiate calls from the wrt54g to the
person that called you without a problem (and this is what made this
problem so annoyingly hard for me to pin down). If you do place a call
from the wrt54g first and cause this problem you can easily fix it by
reseting the wrt54g. Once it's reset the wrt54g can then receive calls ok.
I've reported this bug to Linksys on April 12th, 2005, but I get the
feeling they were just blowing me off when the tech said he'd report it
(i.e. I don't expect them to fix this ever). This is unfortunate, because
otherwise this is a really nice router (especially when you combine it
with the sveasoft firmware). Maybe if everyone who reads this complains to
Linksys they'll actually fix it. I also reported this problem to D-link on
April 13th 2005 in the hopes that they'll add this info to their FAQ.
The only fix I know of is to not use a wrt54g router with this camera (or
to never place an outbound call from behind the wrt54g). I've listed the
results of a few routers I've tested below.
Routers that I've tested that are known to work well with the dvc-1100
are:
* Blitz Wireless Router firmware version 1.08.000.264
* D-Link DI-624 H/W Ver C2 firmware version 2.50
* Linksys BEFW11S4 v2 firmware version 1.45.10
* Linksys WRT54GC firmware version 1.02.8
Routers I've verified do NOT work (i.e. exhibit the "wrt54g" problem
described above:
* Linksys WRT54G v2 firmware version 3.03.6
* Linksys WRT54G v2 firmware Sveasoft Alchemy-pre7a v3.37.6.8sv
* Linksys WRT54G v3 firmware version 3.03.6
* Linksys WRT54GS v.2 firmware version 3.37.6
* Linksys WRT54GS v.2 firmware Sveasoft Alchemy-pre7a v3.37.6.8sv
If you'd like to report a working or non-working router to me you can drop
me an email at "annoyingLinksysDvcProblem.20.jim-j AT spamgourmet DOT
com". Please include the router manufacturer, hardware version and
firmware version you tested with and if you encountered my infamous
"wrt54g" problem, or another problem.
But BEFORE you email me please understand that I don't have time to
provide any tech support. I won't help you forward ports and I probably
won't reply to any emails sent to me. Also, please don't report any more
working D-link routers to me. I assume that all Dlink routers work. Only
let me know if you find a non-working dlink router.
And now for one free bonus solution! The Linksys BEFSR41 v3 firmware
version 1.05.00 has a different problem. It can place outbound calls ok,
but it cannot receive inbound calls at all. It won't even answer the call.
This happens regardless of if you place the Dlink camera in the dmz or
forward the correct ports to it, the behavior is the same. I've gotten
tired of reporting bugs to Linksys, so I haven't told em about this one.
Feel free to report it for me.
I used to think Linksys made the best cheap home routers, but this mess
has changed my mind. Is Dlink now the best, or is there a better brand out
there? I'm not really fond of Dlink routers, but they can't be worse then
the current crop of Linksys routers. Is Netgear any good? I've never used
em.
Sponsored Links
There are 912 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
