VPN / WiFI problem
Forum Smartphones & PDAs : Windows Mobile - VPN / WiFI problem
Archived from groups: microsoft.public.pocketpc (More info?)
Hi,
My campus administrator installed a wireless network recently, and I've
been trying to access it for some time now. This is how it works: the
access point has no encryption, so anyone with a wireless card can get
in. After you get associated, you get an internal IP address through DHCP.
After that, you are supposed to connect to their gateway through VPN. I
have the VPN configured, and working. What bothers me is that I cannot
tell all network applications to use that VPN connection by default. In
another words, if I set Messaging to use the VPN, when I move to a
different network, my PPC will try to connect to that VPN gateway which
is of course inaccesible.
Can anyone point me to a solution?
Thanks,
jps
Sponsored Links
The only way to funnel everything through the tunnel is to add "*.*" to the
exceptions list. While this should work great when you're using the campus
wifi, it will be frustrating when you are on a different network because
there's no way to set profiles for the exceptions list. My only suggestion
would be to add "*.*" to the exceptions when you want to use the schools
network and delete it when you're elsewhere. Is it a pain.....oh very much
so but there's no way around it.
Eric Hicks [That_Kid] (MS-MVP Mobile Devices)
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no
rights...
"Jan Szumiec" <jps@odpisz-na-grupe.com> wrote in message
news:cqbm1m$7po$1@node2.news.atman.pl...
> Hi,
> access point has no encryption, so anyone with a wireless card can get in.
> different network, my PPC will try to connect to that VPN gateway which is
> Thanks,
> jps
Reply to Anonymous
Geez... as if they couldn't use 802.1x instead... Thanks for the
information, it really helped me out :)
Reply to Anonymous
No problem, and I agree 802.1x would've been much easier.
rights...
news:cqctvj$1454$1@node2.news.atman.pl...
>> the exceptions list. While this should work great when you're using the
>> campus wifi, it will be frustrating when you are on a different network
>> because there's no way to set profiles for the exceptions list. My only
>> suggestion would be to add "*.*" to the exceptions when you want to use
>> the schools network and delete it when you're elsewhere. Is it a
>> pain.....oh very much so but there's no way around it.
Reply to Anonymous
Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > VPN / WiFI problem
There are 1030 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
