Help with a new PSU for an SLI system
Last response: in Components
Hi all
I am upgrading to an entire new system, and I have some trouble finding the correct PSU. I have looked at the automatic power calculator, which says I need appr. 325W for my system, but how big a PSU should I purchase then?
I know it also rests on how efficient the PSU is, but would a 500W PSU be enough, or should I get a 600W PSU?
My entire system is as follow:
Motherboard:
ASUS P5N32-SLI Deluxe
CPU:
Core 2 Duo E6400 2.13 GHz
Memory:
Corsair XMS2 2 x 1 GB PC2-5400 CL4
GFX:
2x ASUS EN7900GT/2DHT
Harddrive:
3x SATA 160GB Disc
Beside this, I have a couple of fans, a DVD-RW drive an some other small stuff.
I don't plan on OC'ing my system by much, but on the other hand, I don't want to have my new system ready, but missing 20W of power. At the moment, I am planning on buying a Sea Sonic S12-600 PSU, as people say it is pretty silent, but any other low-noise recommendations would be happily accepted.
Please share your knowledge!
Best regards
Henrik
More about : psu sli system
Please search the forum - this was recently discussed in detail. The Seasonic you mention will easily get the job done. That has to be overkill on paper but I find comfort in PS overkill. PS overload deaths can be nasty.
Hint: 12V current capacity.
Ask the community
