I am constantly having problems with my PC locking up when I am playing games such as F.E.A.R., Age Of Empires III, and Far Cry, and on occassion, Need for Speed Most Wanted.
I have tried a ton of solutions and none of them have worked. I do remember putting thermal paste on it awhile ago (artic Silver 5), and I might have put a layer on that was too thick. Would that be causing it?
Also, i find that even when I play with the case open, i touch my graphics card (X850 pro PCI Express) and its freakin scorching! I swear its close to 100 Degrees Farenheigt!
Is there a program where I can test each component at one at a time (such as graphics card, CPU, Memory, and so forth)?
Is there any free CPU tprturing Programs?
How about graphics card torturing programs?
Have you tried playing at lower resolutions or reducing other graphical features?
Personally, I've had similar problems with an AGP x850pro that I've flashed with an xt/pe bios and added an ATI Silencer 5 cooler.
I notice when I play COD2 at max it will freeze occasionally to which I have reboot the machine. If I lower the resolution to say 1024x768 it runs fine.
I'm leaning more towards it being a power supply problem rather then a cooling problem...
Well it is a cheap Power Supply from a linkworld case I bought on New Egg. Come to think of it I did have an MGE in before it started doing this (My case is an MGE, it came with it. I thought it had blew out when it wouldnt start my PC with my Audigy 2 ZS in it, so I replaced it)...
I took some temperatures using Everest home edition. This was after playing Freelancer for a solid hour at 1024x768:
Then I took more temperatures using Everest while playing F.E.A.R. (sorry no screenie)
GPU Temperatures when exiting FEAR: 105 degrees Celcius, 210 Degrees Farenheight
CPU also hit about 75 C (Pentium 4 520, 2.8 ghz)
You must also note that all of these tempuratures were taken WITH THE CASE OPEN
Thats WAY too hot for this kinda of card in that kind of enviroment (open case).
Someone had said to me that everything in my system is too hot, and that I should take the front fan fan out. I have 4 80 mm fans installed (one in front blowing in, two in back blowing out, and one on the side blowing in)...
Is there anything else I can do or is watercooling (or a new completely rebuilt PC) the only answer?
For my temps, I know it's my case. I have one of those bargain Dell servers (400sc) that I got at a great price. There's only one 92 mm fan that pulls air across the CPU. There is no way to add a fan to the front of the case - unless I make a hole - which I may end up doing. Otherwise, I can live with it.
The room is quite warm, and there are 5 computers in here (and the room is only about 12 x 8), one is next to mine.
Idle temps are as follows:
CPU: 56 Degrees Celcius (133 farenheight)
GPU 52 Celcius (126 Farenheight)
The Graphics card Heatsink is abosolutly scorching!
The Processor Im pretty sure is in acceptable temperature range, as its a prescott Pentium 4 LGA775 processor, and those thigns run really hot so 75 at full usage is about the max threshhold... Or maybe I'm jsut losing it, and everything is too hot.
Could it be becasue of a thick layer of thermal paste was applied to the processor? I remember putting it on and Not knowing what I was doing so I put a little too much and the layer right now is extremely thick. Is that the problem?
Also, my case is still open. I actually tried putting a table fan pulling all the hot air out and it still doesnt fix the problem...
Its probably a faulty component at this point, and not a heat problem. Maybe the graphics card heatsink isnt doing its job or maybe the thermal paste had worn off it so the heat inst transfering correctly or maybe its just too hot in this room and I need to invest in a watercooling system...
Leaving your case open is worse than having it shut. It makes it so there's no airflow through your case. Also, you're not supposed to put a thick layer of thermal paste, just a thin layer, or even a small pea-sized dot in the middle. You're probably going to need to get an aftermarket HSF for your video card. I have the same graphics card, except AGP, and mine never goes over 70 on load, with stock cooling. I bought an Arctic Cooling HSF for mine though, it'll be here next monday and only costs like $20. Might want to try one of those. Other than that, I don't know what else to tell ya. Air cooling should keep your system plenty cool.
