OK I ordered the AMD Athlon 64 X2 4000+ (the one with 1 MB Cache).
I have Hardrive (non-sata but will upgrade that later), Sounds Card (Audigy Pro Gamer still doing great), a case (Antec Sonota II w/450 w PSU), a DVD Burner, and a Monitor (Sceptre X20 20.1" Widescreen LCD)
All I do is game and light online stuff. I will most likely want to upgrade the memory and vid card in a year or two and hopefully make the PC last 4-5 years like my current box has.
So no I don't need to have my games run all out.. they just need to run and be playable.
Now I need to get a Motherboard, Memory and Video Card for $400.
Any suggestions?
I was thinking of these:
Memory - GSkill 1 GB kit or OCZ $114-
http://www.newegg.com/Product/Product.asp?Item=N82E16820231064
http://www.newegg.com/Product/Product.asp?Item=N82E16820227082
Motherboard - will this board do OK?
http://www.newegg.com/Product/Product.asp?Item=N82E16813123007
Video Card - I prefer Nvidia but would go ATI if there is one better:
http://www.newegg.com/product/product.asp?item=N82E16814130017
Thanks for any help!
-Chris
Any suggestions?
-Chris
