Hello, peoples!
I've got a problem that I am desparately trying to solve.
I purchased a new Netgear JFS524 switch for our network and put it in. Everything seems to be connected together correctly, but I can't access anything through that switch.
Physical network:
Server
|-Switch #1-|
|-Switch #2
|-Switch #3
(if the diagram doesn't show it, switches 2 and 3 are plugged into switch 1)
It is switch #3 that isn't working, although it's at the same level as the other switch. I'm kinda stumped.
I thought about cross-over issues, but the JFS524 is auto-crossover sensing and I've tried it from the server side both ways.
Does *any* body have any ideas for me to check?
I've rebooted the laptop several times both while connected and while not connected. It's not even seeing the network. I know that the cable coming from the server works as I've plugged that directly into the laptop and it works.
Help!
TIA,
Mike
one.great.big.festering.neon.distraction
m3+r0p4@93
Physical network:
Server
|-Switch #1-|
|-Switch #2
|-Switch #3
Help!
TIA,
Mike
m3+r0p4@93
