I really hope someone can help me out with my problem. I don't know if this is the correct forum, so please forgive me if i posted in the wrong one.
I have a gigabyte kt266A mobo. 3 partitions were made on the 40gb HD (C, D, and E) with Windows 98SE installed on C: (yes, it's an old setup). Later i wanted to add another, bigger HD (160gb) and install XP on it (make it a dual boot system). The second HD was installed on the 2nd IDE channel as a master ( i work with audio so i wanted as quick transfers as possible). I also wanted 8 partitions on that 2nd HD. Programs would only be installed on the first partition of each disc, all the rest of the partitions would only contain audio files to be streamed from disk.
The technician that did the installation did not use Fdisk to create the partitions before he begun the XP installation but instead he created them while installing XP. As a result, when i boot from XP i see things the way i would expect them:
C - 1st partition of HD #1
D - 2nd partition of HD #1
E - 3rd partition of HD #1
F - dvd drive
G - dvd drive
H - 1st partition of HD #2
O - 8th partition of HD #2
But when i boot from win98se i got:
D - 1st partition of HD #2
E - 2nd partition of HD #1
F - 3rd partition of HD #1
G - 2nd partition of HD #2
H - 3rd partition of HD #2
L - 7th partition of HD #2
M - dvd drive
N - dvd drive
First observation, win98se do not see the 8th partition of the 2nd HD (norton ghost won't, either) maybe because DOS and 98SE reach the size-limit they can read? Can anyone explain that?
Second, everything works fine. Both drives are fat32. Everything works flawlessly... Until now, that i need more space. I can either add a third HD or replace one. Do i need a PCI board to add another HD? In that case, it worries me that it might create a bottleneck since both that HD and the audio card will share the same bus.
I could be wrong, please let me know what you think.
I think it is better if i choose to replace one HD. I have ghost-image backups for the OS partitions, so i would have thought that all i need is replace the 98SE a disk and then restore image. The problem is that (as am told) if i replace the first HD with another one then it will not be a dual boot system anymore, they (technicians) told me that the new first disc will not contain any information about another OS (XP) being on the second HD.
Is that true?
If so, then would the only thing left to do be that i will need to reinstall XP on the 2nd HD?
I wouldn't want to reinstall the XP partition - i've spend too much time tweaking it to get it where it is now
But...
what if, say, I replace the 1st HD, make the same number of partitions on it, then just install win98se on it, then re-install XP (on the first partition of the 2nd disk) and when the istallation is over, i choose to RESTORE BOTH the 98se ghost-image to the 1st (new) HD and the XP ghost image to the 1st partition of the 2nd HD (where it originally was)...????
What then?
Would i end up with everything the way they are now, but with a new HD?
Should't all my programs work the way they work now?
Am i correct in my assumptions or am i simply... wrong?
If i am wrong, then the only other way to avoid re-installations would be to replace the 2nd disk with an even bigger one, make the same number of partitions (do i have to?) and then just load the XP Ghost image. THAT should work, right?
Right?!?!
Please let me know what you think. Any (and i mean ANY) kind of advice would be greatly appreciated.
Thank you so much for taking the time to read all this.
Kind Regards.
