Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Best AGP Card(s) for 18amp Power Supply?
Forum Graphic & Displays : Graphics Cards - Best AGP Card(s) for 18amp Power Supply?
What are the best Video Cards that can run on an 18amp 12volt rail?
My PSU's make and model is "Antec PP-412x 400w". I've read on the side that it supplies 18amps at 12volts.
Having searched all over the place for information, finally I'll just break down and ask all of you about it.
Sponsored Links
What interface do you have? AGP or PCI-E?
Reply to Gary_Busey
- 0 +
Any AGP card will do.
I've got an EuroTech 400W psu with 18 Amps and it managed to power up several cards (6600gt, x800 pro, x850 pro and even a 6800 ultra) and with overclocked ram, cpu and gfx card. Now it's running a 6600gt.
Unless you're running a high freq. Pentium (3.6 and up) you should be fine.
Reply to pmr
The Geforce 6200 (regular) and try to get the version that Unlocks the full 8 Pipelines to same specs as 6600 and overclock to full potential and it'll run as great or greater than the Geforce 6800GTX. I'm Totally going for a PNY Geforce 6200
Offresponce question= "Does this Card Unlock??"
http://www.tigerdirect.ca/applicat [...] u=P56-7016
Reply to YO_KID37
- 0 +
Quote :
It was in the subject, but I should have put it in the post, too; AGP 4x 1.5volt.
Reply to cmdratz
Quote :
My bad, that's the second time I've done that.
As someone else said, pretty much any AGP card will do. ATI.com is having a clearance sale on X850Pro's and X800XL's for $119.
http://shop.ati.com/searchresults.asp?dept_id=39
That's probably the best AGP deal you'll find.
Reply to Gary_Busey
- 0 +
Quote :
Have you tested any other card than the 6600gt (and thank you for that) in a SM2/3 game or two?
Quote :
I am running an Athlon XP 1700+ @ stock 1.47Ghz (with 3 matched 1GB DDR memory modules, 3 Hard Disks and 2 Optical Drives).
Reply to cmdratz
6200 as good or better than 6800 GTX, stop souping him up, that ain't gonna happen.
Reply to MasterLee
- 0 +
Well, all cards were tested in this rig and in a few games. Don´t bother with SM 2 or 3, if u want pure performance go for ati without going homeless. As Gary said, x800xl would be a greate choice. Just squeeze that Athlon XP at least 400 mhz more or you'll have a bottleneck.
Reply to pmr
- 0 +
Quote :
You're kidding right? Why go through all that for 8 pipes? I agree with Busey, go for the X850pro or X800XL from ATI clearence.
Reply to kaotao
Just a note, they removed the X850 Pro's from the ATI.com store. They must've sold their entire stock because the Canadian store doesn't have them either. Glad I got mine when I did.
Reply to Gary_Busey
- 0 +
What are your system specs? CPU? # of Drives? etc. I've used a X800XTpe fine on an original Antec smartpower PSU with 18A 12v rail, but it was an Athlon XP rig with 1 HDD and 1 optical Drive.
Reply to pauldh
- 0 +
Quote :
Antec Midtower Case with 3 80mm fans, Antec PP-412x 400w Power Supply, A-Bit KR7A-RAID MB, 1 PCI 1Gb ethernet card, 1 PCI firewire card, 1 PCI Sound Blaster Live 5.1 card, Athlon XP 1700+ @ 1.47Ghz, 3 Hard Drives (2 40GB Drives in RAID-0, 1 400GB Drive), 2 Optical Drives, 1 Floppy Drive, 4 USB 1.x devices.
I always buy new.
Lately, I've thought on this card the most:
http://www.newegg.com/Product/Prod [...] 6814150166
Yet I've also considered this card:
http://www.newegg.com/Product/Prod [...] 14-161-005
One because of its evenly allocated resources and specifications, the other because of its lower transister count and better (more efficiently) split memory bus.
Reply to cmdratz
- 0 +
In that price range, you'd better go with this:
http://www.newegg.com/Product/Prod [...] 6814102002
Or a 6800gs from XFX.
Reply to pmr
You'd get more performance than any of those cards you're looking at, and for cheaper if you go with the X800XL. I know it's refurbished, but it's refurbished by ATI, straight from the manufacturer, so it's like new, and it's got a warranty. You're shorting yourself if you dismiss it because it's a refurb.
Reply to Gary_Busey
Any GeForce 6200 with a NV43 core should unlock. I believe some cards have the NV44, but I believe that was limited to PCIe TC editions. If you're paying 80 bucks CA, it still probably isnt worth it. Not that its difficult to unlock, just you can get more for your money. I have one that opertes between a 6600 and a 6600GT (stock).
Reply to kmjohnso
- 0 +
Quote :
Just ordered an Enermax 535 watt power supply with dual 22amp 12v rails. Along with it I ordered a new Radeon X850 Pro. I also ordered an Athlon XP 2400+ @ 2Ghz. This upgrade will last me 2 years at which point I'll have enough money for a wholly new PC. Thanks for all your help everyone!
Best regards,
Chris. Dratz
Reply to cmdratz
There are 1281 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
