well i plan to upgrade when the DX10's come out. So i dont want to sink a ton into the best of the best right now. Just a 150 dollar jobber to hold me over.
I don't know about the best, but i am completely satisfied with Zalmans cooler! It's quiet, relatively easy to install and i can overclock the GPU at least 10% mere than with the stock cooler( at least becouse i didn't go further, although i obviously could!). Best money spant
I'm using a VF700-Cu on my 7600GT, and it is essentially inaudible, especially compared to the stock turbofan. I'm not overclocking, but it seems to do well enough.
Sure. Check their website, that's where I found out. As long as there's no physical damage to the card, like a scorch mark or anything that would result from overclocking, you're good.
