Tom's Hardware > Forum > Computer Peripherals > Printers > Cannon i950 nozzle problem
Forum Computer Peripherals : Printers - Cannon i950 nozzle problem
Archived from groups: comp.periphs.printers (More info?)
one of my Cyan nozzles is semi-clogged.
i've done many nozzle cleanings. not a deep cleaning.
any suggestions? (it's the one that prints out under 'B')
tia
Sponsored Links
Are you using and have you always used Canon ink?
>tia
Reply to Anonymous
- 0 +
Plagerism - the question during the McCarthy witch hunts was "are you now or
have you ever been a member of the Communist party? Measekite asks everyone
with a printer problem if they use non-OEM inks. Just looking frantically
to bolster his biased, inexperienced opinion that printers only have head
clogs with aftermarket inks.
"measekite" <inkystinky@oem.com> wrote in message
news:KXFse.3498$NU5.3338@newssvr13.news.prodigy.com...
>>tia
Reply to BURT
- 0 +
Judy - go on to the following two sites and read their information about
printer maintenance (primarily Canons). First read their cleaning
suggestiong and then, if you still have questions or a continuing problem,
sign in and ask any questions you have on the Nifty-stuff forum. You should
try one deep cleaning cycle before you do any of the more involved cleaning
tasks and then run the printhead test. Of course, the other problem might
be a cartridge that isn't feeding ink properly, so it would also be wise to
try a new cartridge before doing anything more complex.
Although there are some poor quality aftermarket inks you should avoid, head
clogs can occur with OEM and non-OEM inks. Best to study these sites and be
more educated with regard to avoiding the problem as much as possible and
fixing it when it happens.
http://www.nifty-stuff.com/forum/
http://www.neilslade.com/papers/inkjetstuff.html
"Judy Cosler" <jcosler@starpower.net> wrote in message
news:n926b1pddud6oid1dtjkc4he4bafhoe1j7@4ax.com...
> tia
Reply to BURT
- 0 +
measekite wrote:
> If you believe that then I would like to sell you my used underwear.
Watch this guy as he sounds like some wacko pervert who's into used
underwear.
Stay away form the children, pervert.
Frank
Reply to frank
> underwear.
> Frank
Did you pass the sniff test?
Reply to Anonymous
yes & yes.
On Fri, 17 Jun 2005 19:58:34 GMT, measekite <inkystinky@oem.com>
>>tia
Reply to Anonymous
thank you, Burt! a real answer.
On Fri, 17 Jun 2005 22:45:10 GMT, "Burt" <sfbjgNOSPAM@pacbell.net>
>> tia
Reply to Anonymous
Judy Cosler <jcosler@starpower.net> wrote in
news:qiu7b1hnd9oi8kvaiq1opu7ltiq9pcms77@4ax.com:
> yes & yes.
Translation: Judy used genuine Canon OEM inks and the printhead clogged.
OEM ink promoter Measekid's in shock. The world awaits his response in
hushed silence.... not.
Brian Potter
>>>tia
Reply to Anonymous
There are 562 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
