Hello,
We, members of the forum Gathering of Tweakers, specifically
Het Logitech PLOPJES probleem topic DEEL 4, started this topic in the Netherlands due to an overwhelming number of complaints concerning noise issues regarding Logitech Audio Systems.
This involves, in particular, the Z-5500 and X-530 speaker set, but also other Logitech audio models suffer from this issue.
Let us first explain what the problems are about. There are 3 main issues:
1. "Popping" noises from the speaker system. When light switches, blenders, fridges or other electrical appliances are switched on or off, a very loud and disturbing "popping" noise is generated in the audio systems.
Sometimes the volume of this “pop” is at such a loud level, that you do not want to be in the same room when it occurs.
2. An irritating permanent ‘humming noise’ coming from the subwoofer.
3. And in some occasions the Z-5500 picks up radio signals that can be heard. And that without any other appliances connected.
Since most people do not realize that the problems are part of their Logitech speaker system, they usually blame their indoor electrical system or other electrical appliances.
This idea was (and still is) stimulated by the things mentioned in the customer support section on Logitech's website.
As a result, many people are buying EMI filters, which of course do not provide a solution.
Some members have started the initiative and contacted Logitech about these issues in order to solve the problems.
At first, Logitech even denied that a problem existed which affected their speaker systems.
However, a few members, who are qualified engineers, did investigate the Z-5500 and some other audio models and figured out exactly what is causing the noise problems.
With some minor modifications they managed to solve almost completely the noise issues.
It became very clear that the noise problem is a result of a design error and affects not only the Z-5500 and the X-530, but also other Logitech audio models.
There is no doubt that the Logitech design staff has repeatedly underestimated the importance of a proper shielding of the respective audio units.
May we point out that it is common knowledge that a proper shielding of audio equipment is essential, in order to avoid noise problems.
However, it took an incredible 5 months for Logitech to accept this fact.
Due to our efforts Logitech was not able to deny any longer that a serious problem exists regarding their audio units.
Since Logitech showed no initiative at all to change their FAQ section, we had to press hard for Logitech to do so!
As a result the FAQ were somewhat altered and a refund policy, concerning the Z-5500 as well as the X-530, is offered.
May we draw your attention to the fact that Logitech is still talking about a "production error". However, the noise problems are definitely a result of a design error!
Now, 8 months later, after many emails, phone calls, meetings, prototype testing and even some visits of members of Logitech’s Technical staff (to test some experimental units at the homes of members), we feel that all our efforts were in vain.
There are hardly any improvements at all, we all still have a defective audio unit.
Nothing constructive has been undertaken by Logitech in order to solve the design issues!
We feel that Logitech has been buying time in order for us to lose interest and to prevent us from going public with this issue.
What strikes us most, is that Logitech is still selling their audio products worldwide, while realizing very well that these products suffer from a design issue.
We feel that selling a product with a defect, to customers who trust Logitech to provide a product which will perform according to the things mentioned in the sales literature, is far from fair practise.
Last but not least, Logitech is trying to make us believe that the noise (popping) problem is very localized and only concerns The Netherlands and Belgium.
However, this is a far cry from the reality.
By using Google it is not very hard to find many, many, forums (worldwide) that are related to this “popping" problem.
Reason why we feel we have to share this information with other (potential) Logitech customers worldwide, bearing in mind that this action will make Logitech seriously consider to take proper and constructive action in order to solve these design issues.
Best regards,
The Forum members
Representatives:
BvB
RV
MvH
DW
RC
If you have the problem to, we would be happy if you send us a E-mail: plopjesprobleem@xs4all.nl
