G
Guest
Guest
a couple weeks ago i tried installing redhat version 6.1 on my system, but it wouldn't work. i created an unformated partition on my hard disk and went through the setup procedure. when i got to the drive mounting part i couldn't create a folder/directory (whatever they are called) for the kernel ie. /root. no matter what size i created it said it was too big.
i downloaded the newest version 7 or 7.1 don't remember so i will see if this helps. i haven't had a chance to try it since i have been having some other technical difficulties, but wanted to see if anyone knew what i was doing wrong before so i don't encounter the same problem.
thanks,
De
i had a drink the other day... opinions were like kittens i was givin' away
thanks,
De
