Tom's Hardware > Forum > Computer Peripherals > Printers > Any problems using USB 2.0 hubs with Scanner + Printer
Forum Computer Peripherals : Printers - Any problems using USB 2.0 hubs with Scanner + Printer
Archived from groups: comp.periphs.printers (More info?)
I'm running short on USB connections, and it occurred to me that I can
save a connection or two by using a USB 2.0 hub on my Canon Scanner,
i850, and ip4000. I can't think of any time when I'd be using more
than one simultaneously. Any known problems with this?
Sponsored Links
"_RR" <_RR@nomail.com> wrote in message
news:h8icb15g9u9m0o149vgb7jui0dhb1fphhi@4ax.com...
As far as I know there is no reason why you couldn't use both at the same
time - that is the point of a hub.
Reply to Anonymous
- 0 +
"Caitlin" <caitlin_online_nospam@hotmail.com> wrote in message
news:42b68fe7$0$27863$61c65585@un-2park-reader-01.sydney.pipenetworks.com.au...
Nothing wrong with using a hub. You can use them at the same time- But I
would get a self-powered one (one that has it's own power supply). Some USB
devices draw power through the USB cable. Many of the USB hub problems I
have encountered were caused too much current drain and were solved by a
self powered hub.
Mark
Reply to mark
Works for me.
Reply to Anonymous
Should work fine. Of all the USB devices I have, only one caused
trouble and that was my PDA. It wouldn't connect if the cradle was
connected to any USB hubs but when plugged directly to PC USB port, it
worked fine. Dunno why it is so.
Ideally all USB devices should be fine with any USB hubs. just make
sure you use USB 2.0 hubs when using USB 2.0 devices or it'd be
reduced to 1.1 speed.
When you hear the toilet flush, and hear the words "uh oh", it's already
too late. - by anonymous Mother in Austin, TX
To reply, replace digi.mon with phreaker.net
Reply to Anonymous
"Impmon" <impmon@digi.mon> wrote in message
news:ouaeb15ke2kjm400n6iaghqqckkss79q9u@4ax.com...
Had same problem with my early model IPAQ Pocket PC.
Reply to Anonymous
- 0 +
You would have to use a mains powered hub.
Reply to shooter
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
