Hi,
My specs are in my sig so I won't repeat them in the post. Bios is updated to F2.
The symptons I have are, when loading Windows XP, there is a 30 seconed black screen, between the bios post and the XP Logo. To remedy this, I thought I would update the drivers. This caused the DVD drive to dissapear and a tone more errors. Windows would load saying the GA336 (or something) was disabled, so I tried to enable it, reboots. I tried updating the drivers, it reboots. I rolled back the drivers and rebooted. Attempting to reconfigure the bios to make sure it was all ok, resulted in me needing to clear CMOS data (horrible, had to short out two pins!!!). The DVD drive was eventually fixed with installing the SATA II drivers that I put on the floppy disk before installing Windows. It now says a standard dual channel PCI IDE controller, rather than the gigabyte hardware it had before (exact name I cant remember, was a controller of some kind). So installing the latest chipset drivers was a big no no.
Additionaly, I have recieved slight jumping in games/tests, where frame rates drop drasticly, only to return moments later. This is not a constant problem, and may have been fixed with a graphics card driver update.
Finally, what really concerned me, after leaving the PC on for a few hours doing nothing. I came back, to find the mouse and keyboard were not responding. The lights on the mouse and the keyboard were also off. The system would only respond to the power button at the front.
Could anyone please give me some good advice on what to do? Or do I need to post more information? Many thanks.
