Archived from groups: comp.dcom.lans.ethernet (More info?)
Hi all,
I have a Ethernet N/W(100 Mbps) ,the total distance between an
Ethernet Transmitter and Receiver at the absolute end points of the
network should be 500 meters without any repeaters.
But what i see of the cabling standards
100BASE-TX and 100 Base-T4 support a maximum distance of 100 meters.
100 Meters is not enough for my application can anybody suggest me any
alternative where in the max distance is 500 meters.
"prav" <praveenkn123@yahoo.com> wrote in message
news:863df22b.0406132105.71dfd5f@posting.google.com...
> Hi all,
you are mixing up how far a segment can go (which depends on the kind of
segment) and how far an ethernet collision domain can go (which is limited
by propagation delay, the minimum length packet and the data rate).
if you have 10 Base-F only, and no repeaters, then you can go 4 Km.
if you run at 100Mbps then you will need switch(es), and / or you have to
use full duplex, so there arent any collisions, since the limit at 100M is
less than 500m.
> Thanks in advance
> Rgds,
> prav
Regards
> 100baseFX should do at least 500m, maybe more.
2 km, according to the spec. So that should work fine for him.
glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote in message news:<yxbzc.87000$3x.51606@attbi_s54>...
Hi,
According to IEEE 802.3 the max segment length for 100baseFX link is
400m for half duplex .
See clause 24.1.2 of IEEE 802.3 2000 edition
> Hi all,
> Thanks in advance
> Rgds,
> prav
You considered 10base5 ? )
BL
As the days go by, we face the increasing inevitability that we are alone in
a godless, uninhabited, hostile and meaningless universe. Still, you've got
to laugh, haven't you? - Holly
Hi,
I want it on a copper link not fiber link.
Rgds,
prav
Rich Seifert <usenet-@-richseifert-dot-com.invalid> wrote in message news:<usenet--741012.09160714062004@news-central.dca.giganews.com>...
> In article <863df22b.0406140419.2b623d4b@posting.google.com>,
> Correct. Therefore, use the link in *full-duplex* mode, which easily
> meets your length objective.
500m sounds like between different buildings (ground stakes).
You'd best go fiber for the lightening protection. Otherwise,
look for 10base5 coax.
If you still insist on 100 Mbit/s, you'll have to look to
proprietary vendors (BlackBox?). AFAIK, there is no copper
standard that does 100 Mbit/s over 500m.
Do not expect to run 100baseTX over 500m. I've never heard of
anyone running it that far (100m spec, ~170m max reported working).
Running any copper data between buildings is asking for trouble.
If you're lucky, only burnt out ports and cards.
On 2004-06-15, glen herrmannsfeldt <gah@ugcs.caltech.edu> wrote:
[snipfest]
> The OP asked for 100Mbps.
Well, uhm, 100base5, then? ;-)
But seriously, between stretching the time-space continuum (so you can
get away with 10 metres of cat5 to do 100BaseTX on) and going fibre, I
think OP is out of options. Or maybe he could invent 100baseT4-stretch
that'll go up to 1000M on cat7, or something like that.
j p d (at) d s b (dot) t u d e l f t (dot) n l .
You can always attach empty cans and shout in them.
jpd wrote:
(snip)
Somewhere on ieee.org I saw something about a 100Mb/s system
using the same signaling as 1000baseT. It has reduces RFI
emission, and also longer distance range, though I don't remember
that it would reach 500m.
I asked about it here, and it seemed that even Rich Seifert
didn't know about it, so I wouldn't expect it to be available
anytime soon. It does seem an interesting idea, though.
There have been suggestions along the line of running
802.11g through coax, with the proper attenuators if needed.
I don't know that anyone has tried it.
With the right transformers it might be possible to run
100baseTX through two coaxial cables. One might even arrange
the proper isolation for ground differences. (Ground the
shield at one end, run the other end into a thick walled
plastic box, through repeaters with a well isolated power
supply, and then out to normal termination. Best would be to
run fiber through that short link. I could imagine it, I doubt
anyone would ever build it.
Fiber is really the best solution. The cable doesn't cost
much more, the connectors do, but averaged over the length of
the cable it isn't that much more.
William P.N. Smith wrote in message news:<m7stc0pcku4mv7ugmkl3kr1noi1njkv6jv@4ax.com>...
> You can't get 500M 100BaseT Ethernet over copper. It's either got to
> be some DSL conversion, fiber, wireless, or something else.
praveenkn123@yahoo.com (prav) wrote in
news:863df22b.0406160128.79b147cb@posting.google.com:
> What is DSL conversion???
Basically using DSL technology (VDSL/SDSL/etc) to transmit data over your
local network. This is similar to the technology used by ISPs to provide
broadband to consumers - however you're running it over your own lines (so
they're usually no monthly fee). However, with DSL you're limited to about
5 - 8 mbits.
Anong these lines, AMP claims that 100BT will run 200M over Type 1 cabling
(150ohm STP used for Token Ring networks) using their baluns. Years ago, at
the Kennedy Space Center, NASA was running a T1 signal several 10s of
thousands of feet on some exotic cable using one of our data sets designed
for 6000 feet but rarely drove 4000 feet on 'normal' circuits. The point is
that the quality of the cable very much impacts the performance. Find a
cable that meets the minimum requirements at the length you're after, and
away you go. Having said that, it seems to me that searching for copper
cable to run an ethernet signal 500M might be difficult, even if you have a
good understanding of the electrical parameters associated with cabling and
ethernet. Fibre is good. Another alternative might be the Long Range
Ethernet technology that Cisco bought. Too bad they don't have a pair of
standalone ethernet 'data sets' using LRE, instead you have to buy a
multi-port LRE switch for one end, and the standlone box for the other. It
does have quite impressive speed/distance performance.
Dave
"glen herrmannsfeldt" <gah@ugcs.caltech.edu> wrote in message
news:AwPzc.38309$2i5.25941@attbi_s52...
> jpd wrote:
> (snip)
> -- glen
"Lucas Tam" <REMOVEnntp@rogers.com> wrote in message
news:Xns950A6361711C4nntprogerscom@140.99.99.130...
> 5 - 8 mbits.
Cisco call this approach Long Reach Ethernet. Speed is cable length
dependant, typically <15Mbps, but as it's designed to run over cat3 you
might get an improvement on this using cat5 or better.
If you are looking for inter-building connetivity and don't want to go down
the fibre route then some line of sight device (laser based), may be an
option.
BL
"The object of war is not to die for your country but to make the other
bastard die for his." - General George S. Patton
