power supply with build in fan speed regulator
I'm looking for a power supply min600w that has build in fan speed regulator(turns off the fan when it is not needed)
8 answers Last reply
More about power supply build speed regulator
  1. I use mostly antec PSU's this one looks like it fits your feature requirements.
    Antec TP3-650
    Features:
    Three 12V output circuits provide added system stability
    Accurate power rating allows TruePower Trio to deliver its full rated power, 24 hours a day rated at 50ºC
    Fan Only power connectors allow TruePower Trio to control case fan speeds, reducing total system noise
    Dedicated outputs for stable output and less ripple noise
    Feedback loop circuits for tighter load regulation (±3%) to maintain accurate voltage to all components
    Heavy duty protection circuitry prevents damage resulting from short circuits (SCP), power overloads (OPP), over voltages (OVP), and under voltages (UVP)
    Power Factor value up to 99%
    Gold plated connectors for superior conductivity
  2. Very true. The only time fans should stop is when the PC is powered down. I wasn't sure if he meant OFF because he used OF.
  3. Here is a PSU with a built in fan adjuster that you can turn to change the speed but it doesnt turn the fan all the way off.
  4. Quote:
    HA. no.
    Thats PSU is a POS. it will blow in 2 months and fry every piece of hardware u have
  5. find me a fanless power supply that can produce more than 550w, for about the same price.
  6. Well I've been uding that PSU for about 1.5 years and no problems. cool led lights in it too you can even change the color.
  7. as psu from my link, that's about 170$
Power Supplies Build Fan Speed Components Product
