Sorry to make another topic, but I have to return this laptop in less than two hours so I need to figure this out as soon as I can.
But I bougt this ram http://www.newegg.com/Product/Product.asp?Item=N82E16820231064 and this motherboard http://www.newegg.com/Product/Product.asp?Item=N82E16813128321, it's not getting all the way to instaling the operating system, and I had a problem while running memtest, someone suggested I upped the voltage on the ram, but when I get into the bios settings it dosen't give me the specific numbers, next to ram it just says "normal" then if I try to change it I can add +0.1, +0.2, or +0.3, so I don't know which to choose.
Like I said I have to return this laptop very soon so I'd rather not add .1 volt, run memtest, add .1 volt, run memtest, etc...
