Archived from groups: microsoft.public.win2000.dns (More info?)
Eric wrote:
> Hi,
> My DNS domain name Windows 2000 server is example.com
> But the web site example.com already exist so my server want to
> connect to Internet everytime!
> My server is the PDC and the DNS server.
> I would like to change my domain name because the XP PRO workstation
> are very slow to connect. (I don't want to do a dcpromo)
> Do you know a solution to this problem?
A) Are you using a firewall/NAT device between your Internet router and LAN,
and using private IPs on the LAN? You should be...
B) All servers and workstations should specify *only* the internal
AD-integrated DNS server's IP address in their network settings. The
AD-integrated DNS server should be set up with forwarders to your ISP's DNS
servers for external resolution. See
http://support.microsoft.com/defau [...] -us;300202 for more
info.
> I need some help.
> Thanks.
