Ok well my E6300 arrived yestoday and finished building my comp yestoday. It was my first time building a comp too, and everything went well. Installed windows and did sum benchmarks / played some games.
Anyway, the mobo i'm using is Gigabyte DS3. Here are the problems.
One of my harddrive doesnt' show up in my computer. But it shows up in device manager? weird. Another problem is how do i set the RPM of the fans in my computer? My cpu fan is running rather low , around 1000-1300. In addition the fans on the case are connected directly to the PSU, i dont' think i can change speed on those or monitor those right?
Last thing, i have 2 usb ports and 1 firmware port ON MY case. THe cable provided for the USB does not really match the MOBO's usb connection port. THe mobo has like 10 pins, while the USB cable has only 5 :/ And i have no clue where to plug in the firmware to.
Oh and also i've experienced about 2-3 random restarts from my computer yestoday. I'm on stock cooling, my cpu temps are usually around 40 c
thx
thx
