http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2240432&CatId=2259
this OCZ "overclocking" ram with this Asus "flagship" Motherboard
http://www.asus.com/products4.aspx?l1=3&l2=101&l3=0&model=...8&m
*Oh, and will this board support the new 65nm AMD processors?*
because I heard that OCZ ram doesn't really work with Asus Motherboards.
But i hope this does.
and how far do you think i'll be able to OC the 3000+ with a stock fan?
may be around 1.8 to 2.6?
Thanks.
*Ah, I think i have a problem. I am planning to put in a IDE HD and a CD-RW with the DVD-rom and i think they are ALL ide devices..
Are there any way to use all of them?
Thanks.
