Power failure, now no DNS?
G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
I am running DNS locally on a Win2k3 box, and after a
power failure, the local DNS server does not seem to be
responding. When I drop to DOS and do nslookup, it tries
to find a DNS server at 127.0.0.1, but says DNS request
timed out.
I tried removing DNS and readding through Add/Remove
Windows Components, and still no luck.
I dont see any glaring errors in the event log, except
for the following:
Event Type: Information
Event Source: DNS
Event Category: None
Event ID: 5504
Date: 07/11/2004
Time: 6:21:24 PM
User: N/A
Computer: DELL8100
Description:
The DNS server encountered an invalid domain name in a
packet from 127.0.0.1. The packet will be rejected. The
event data contains the DNS packet.
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
Data:
0000: bf c6 01 00 01 00 00 00 ¿Æ......
0008: 00 00 00 00 03 77 77 77 .....www
0010: 06 67 6f 6f 67 6c .googl
these are just tests i have been trying through nslookup.
thanks,
dave
G
Guest
Guest
Hi David
A few questions:
1. Is this a DC?
2. Does the zone exist for the domain that this server is in?
3. Are the zones AD integrated or standard primary?
4. What happens if you point the preferred DNS settings on the NIC to the IP
instead of the localhost address?
Kind regards
Mark Renoden [MSFT]
Windows Platform Support Team
Email: markreno@online.microsoft.com
Please note you'll need to strip ".online" from my email address to email
me; I'll post a response back to the group.
This posting is provided "AS IS" with no warranties, and confers no rights.
"David Marr" <dave@phormat.com> wrote in message
news:2b62201c4679c$7bc9d340$a301280a@phx.gbl...
timed out.
for the following:
Event Source: DNS
Event ID: 5504
Date: 07/11/2004
Time: 6:21:24 PM
User: N/A
Computer: DELL8100
Description:
Data:
thanks,
dave
G
Guest
Guest
>-----Original Message-----
>Hi David
>A few questions:
>1. Is this a DC?
is in?
>Kind regards
>Mark Renoden [MSFT]
Thanks for the reply Mark.
It is not a domain controller. This is just a simple home
setup, so Active Directory is not installed either.
Zones are all primary, and I am pointing nslookup to the
ip (127.0.0.1).
Any help would be greatly appreciated!
Thanks again,
Dave
G
Guest
Guest
Dave -
I have a similar setup at home. I use my Win2K3 Server
for both routing and DNS lookups. My client PCs know only
about the Server, not about my ISPs.
1) I would recommend avoiding the use of the loopback
address, and use the same IP address the clients will use
to resolve DNS requests. You should have a static IP
address bound to at least one NIC. If you have more than
one NIC, use the internal NIC (attached to your local
network), not the one connected to the ISP.
2) Check connectivity to your Router/ISP. If you can't
ping your gateway, you can't get out and won't resolve DNS.
3) check and update your root servers list.
4) Make sure you don't have "." listed in your DNS tables.
Good luck!
Scott.
>>Hi David
>>A few questions:
>>1. Is this a DC?
>is in?
>>Kind regards
>>Mark Renoden [MSFT]
>ip (127.0.0.1).
>Thanks again,
>Dave
Subject: Power failure, now no DNS?
From: "David Marr" <dave@phormat.com> Sent: 7/11/2004
4:12:06 PM
timed out.
for the following:
Event Source: DNS
Event ID: 5504
Date: 07/11/2004
Time: 6:21:24 PM
User: N/A
Computer: DELL8100
Description:
Data:
thanks,
dave
G
Guest
Guest
Hi David
So what DNS records would this server be attempting to register against the
DNS server? Are you able to explain what zones you have and what DNS suffix
this server may be configured with? Feel free to email me directly if you'd
like to take the details offline.
Kind regards
Mark Renoden [MSFT]
<anonymous@discussions.microsoft.com> wrote in message
news:2adbc01c467a2$d5f43210$a401280a@phx.gbl...
>>Hi David
>>A few questions:
>>1. Is this a DC?
> is in?
>>Kind regards
>>Mark Renoden [MSFT]
> ip (127.0.0.1).
> Thanks again,
> Dave
