Please Help! I don't know where else to turn.
Asus A8N-SLI Deluxe
AMD X2 3800+
X-Fi Platinum
WD Raptor 74 GB (OS Drive)
Seagate 7200.10 320 GB w/ 16mb cache
Windows only shows one cpu in task manager and I don't have the option to show two cores. Also, I know two core are not being used because CPU frequently maxes out with single tasks. However, "My Comptuer" --> properties --> General shows "AMD X2 Dual Core 3800+." Device manager does not show any processors installed.
I installed Windows (old copy that does not include either SP1 or SP2), with little trouble. When I started Windows Update, I was prompted directly to SP2 (in the past I have done SP1 and then SP2). I installed the mobo nForce 4 drivers and the cpu drivers. No luck. Flashed BIOS. NO LUCK. Installed newer nForce 4 drivers from nvidia.com. NO LUCK! Installed cpu drivers from AMD.com. NO LUCK!!!
Am I an idiot?! Please help.
Oh another thing, in Device Manager, "Computer" only shows as "Standard PC" and not "ACPI computer"
Asus A8N-SLI Deluxe
AMD X2 3800+
X-Fi Platinum
