G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
Hello,
I have a small home/office network. The server and domain controller is
win2k sp4+isa2000+exchange2000.
I had many errors in system log with regards to to dns, netlogin etc...
By reading this newsgroup, I managed to correct them all.
Both the ADSL PCI modem and the network adaopter "Register this connection's
addresses in dns" are checked.
The problem today is even though no error is shown in the log files, I have
intermittent problem of network connection loss and delay that can take 3 to
30 minutes. During this time, I lose the server, and other programs like ISA
Client will lose connection with the ISA server; Outlook will not be able to
contact the Exchange server and no Internet will be available.
After this time, things will be back to normal and no error will show up in
the log files on the server nor on the client side.
Here is a Netdiag output which shows some errors that I don't know where to
look for correction.
Thanks for you help
Computer Name: cabal
DNS Host Name: cabal.ventura.local
System info : Windows 2000 Server (Build 2195)
Processor : x86 Family 6 Model 6 Stepping 0, GenuineIntel
List of installed hotfixes :
KB820888
KB823182
KB823559
KB824105
KB825119
KB826232
KB828035
KB828741
KB828749
KB835732
KB837001
Q147222
Q828026
Netcard queries test . . . . . . . : Passed
[WARNING] The net card 'Alcatel Speed Touch PC #3' may not be working
because it has not received any packets.
Per interface results:
Adapter : Local Area Connection
Netcard queries test . . . : Passed
Host Name. . . . . . . . . : cabal
IP Address . . . . . . . . : 10.10.1.1
Subnet Mask. . . . . . . . : 255.0.0.0
Default Gateway. . . . . . :
Dns Servers. . . . . . . . : 10.10.1.1
AutoConfiguration results. . . . . . : Passed
Default gateway test . . . : Skipped
[WARNING] No gateways defined for this adapter.
NetBT name test. . . . . . : Passed
No remote names have been found.
WINS service test. . . . . : Skipped
There are no WINS servers configured for this interface.
Adapter : {D63C5ADD-A36E-46EC-81AF-E6BF09B744FF}
IP Address . . . . . . . . : 80.1.36.217
Subnet Mask. . . . . . . . : 255.255.255.255
Default Gateway. . . . . . : 80.238.1.136
NetBIOS over Tcpip . . . . : Disabled
Dns Servers. . . . . . . . : 217.136.10.22
217.136.10.21
IpConfig results . . . . . : Failed
[WARNING] Your default gateway is not on the same subnet as your
IP address.
Default gateway test . . . : Passed
NetBT name test. . . . . . : Skipped
NetBT is disabled on this interface. [Test skipped]
NetBT is disable on this interface. [Test skipped].
Global results:
Domain membership test . . . . . . : Passed
NetBT transports test. . . . . . . : Passed
List of NetBt transports currently configured:
NetBT_Tcpip_{38C9C4DC-A94E-48FB-A0CD-53DDCC4FCF38}
1 NetBt transport currently configured.
Autonet address test . . . . . . . : Passed
IP loopback ping test. . . . . . . : Passed
Default gateway test . . . . . . . : Passed
NetBT name test. . . . . . . . . . : Passed
Winsock test . . . . . . . . . . . : Passed
DNS test . . . . . . . . . . . . . : Failed
[WARNING] Cannot find a primary authoritative DNS server for the
name
'cabal.ventura.local.'. [RCODE_SERVER_FAILURE]
The name 'cabal.ventura.local.' may not be registered in DNS.
[FATAL]: The DNS registration for 'cabal.ventura.local' is
incorrect on all DNS servers.
PASS - All the DNS entries for DC are registered on DNS server
'10.10.1.1'.
[WARNING] The DNS entries for this DC are not registered correctly on
DNS server '217.136.10.22'. Please wait for 30 minutes for DNS server
replication.
DNS server '217.136.10.21'. Please wait for 30 minutes for DNS server
replication.
Redir and Browser test . . . . . . : Passed
List of NetBt transports currently bound to the Redir
The redir is bound to 1 NetBt transport.
List of NetBt transports currently bound to the browser
The browser is bound to 1 NetBt transport.
DC discovery test. . . . . . . . . : Passed
DC list test . . . . . . . . . . . : Passed
Trust relationship test. . . . . . : Skipped
Kerberos test. . . . . . . . . . . : Passed
LDAP test. . . . . . . . . . . . . : Passed
Bindings test. . . . . . . . . . . : Passed
WAN configuration test . . . . . . : Passed
Entry Name: telnet
Device Type: Framing protocol : PPP
LCP Extensions : Disabled
Software Compression : Enabled
Network protocols :
NetBEUI
IPX
TCP/IP
IP Address : Specified
Name Server: Specified
IP Header compression : Enabled
Use default gateway on remote network : Enabled
Connection Statistics:
Bytes Transmitted : 3854623
Bytes Received : 27304610
Frames Transmitted : 28945
Frames Received : 68090
CRC Errors : 68090
Timeout Errors : 0
Alignment Errors : 0
H/W Overrun Errors : 0
Framing Errors : 0
Buffer Overrun Errors : 0
Compression Ratio In : 0
Compression Ratio Out : 0
Baud Rate ( Bps ) : 3360000
Connection Duration : 51832451
Modem diagnostics test . . . . . . : Passed
IP Security test . . . . . . . . . : Passed
IPSec policy service is active, but no policy is assigned.
The command completed successfully
Hello,
Thanks for you help
KB820888
KB823182
KB823559
KB824105
KB825119
KB826232
KB828035
KB828741
KB828749
KB835732
KB837001
Q147222
Q828026
217.136.10.21
IP address.
Global results:
name
'10.10.1.1'.
replication.
replication.
Entry Name: telnet
Network protocols :
NetBEUI
IPX
TCP/IP
CRC Errors : 68090
Timeout Errors : 0
Framing Errors : 0
