Yes No
Ads
Tom's Hardware > Forum > Video Games > General Discussion > Help!!! Freezing solid in several games!
Forum Video Games : General Discussion Help!!! Freezing solid in several games!
Hello,
I'm getting very frustrated with my upgraded computer; it freezes while playing several different games--locks up tighter than a chastity belt before prom night, necessitating a hard restart. Ugh! Within Windows, all works perfectly with ONE EXCEPTION: 3 times the system has similarly frozen, while burning a CD...but at no other time. CTRL+ALT+DEL doesn't work, NOTHING works.
Here's the info--I'm a serious long-time gamer who's also a hardware validation tech, so I see and get to play with a LOT of hardware, so I'm not a newbie:
Win 98 SE, brand new FDISK/FORMAT/reinstall after upgrading the system to a Duron 800 (stock speed--for now), 128 MB Micron PC-133 SDRAM, ABIT KT7A motherboard, ThermalTake SuperOrb HS/F, and heck, I even upgraded the power supply from a 235W unit to an Enermax 350W, dual-ball-bearing fan unit, thinking a lack of ample power was the problem
-ASUS V6600 (Pure) 32 MB video (NVidia GeForce 256); Detonator 6.50 drivers
-Sound Blaster Live! Value; drivers downloaded from web last week
-SMC network card
-Desktop resolution set to 1024x768x32, which is the same setting I usually play all my games at
-DirectX 8.0a downloaded and installed
-Games where freezing occurs: Quake 3, Crimson Skies, Unreal Tournament; sometimes within 10 minutes, sometimes after an hour and a half, but I can't remember the last time I actually exited the game the PROPER way (all games were updated with the latest patches)
-Motherboard Monitor 5.5 installed (though turned off during game-playing): CPU temp never exceeds 45 degrees Celsius
-Absolutely NO TSRs running in background (I'm very anal about this), all power-saving modes are turned off (to prevent problems while burning CDs), no screensaver in use either
For the record: The old platform was Win 98 SE, Celeron 300A overclocked to 450, 128 MB PC-100 SDRAM, ABIT BH6 (rev. 1) motherboard...and THIS thing was SOLID. It NEVER froze during ANY game, nor did it ever freeze while burning CDs. It was rock-solid stable for over 2 years (though framerates were getting pretty unplayable with the newer games, which is the reason for my upgrade).
So, I'm guessing it HAS to be one of the new parts that is faulty...but want to be sure of it before I take the matter up with my vendor. I'm frustrated as hell after spending about $450 CDN for all the upgrade parts--things work great, except for the damn freezing!
Please help! What seems to be the most likely culprit(s)?
Thanks,
Coelacanth
Reply to Anonymous
First of all if it's only locking up during games and cd-burning, then we probably should start there. Is the video card by any chance incompatable with the motherboard? I don't know, but I would check their website. I read somewhere that someone was worried about that videocard being incompatible.
What burner are you using? What software are you using? I've never had a burn freeze on me, but I've had problems burning cd's using a cheap cd-rom drive.
I'm not much help, but hopefully someone will jump in.
<font color=red>Did you ever wonder WHY aliens only abduct idiots?</font color=red>
Reply to dhlucke
Does Abit use Via? If so I didn't see you mention the lates 4-in-1 drivers. If it doesn't(use Via) sorry for the post, and if you already did that, I could understand you thinking it not worth mentioning. Hope you solve your problem.
There is no problem that an Optimator can't solve.
Reply to Anonymous
Actually, I did install the latest VIA chipset drivers (4.29v)...and after doing some in-depth research, I turned up some rather disturbing information on VIA's (crappy) bus-master drivers, data loss while copying large files between two IDE channels that are both using DMA, SoundBlaster Live! soundcards which exacerbate the problem, and I've done some initial testing myself (now my system is a test-bed!)...
Guess what? My computer benchmarks with faster disk and graphics performance when I DON'T install the VIA drivers!!!
This is very concerning...
Reply to Anonymous
There are 1999 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Video Game of Thrones Season 2e9 - Blackwater
By Brett928S2, 1 hour ago:
Hi :)
SPAM...REPORTED...
All the best Brett :)
Best offers
Top experts
