Hi all,
I'm building a new computer and I've never really done it before. I was wondering if you could give me any advice on what to buy. I'll paste below what I've rounded up so far. I have between $1500 and $2000 to budget but if I can build it for less then that's great. I want a good gaming computer that will last me for a good 2 to 3 years. I'd also really like some advice on a motherboard (for example, is crossfire worth it?). Thanks a lot for whatever help you can give me.
Here's my build:
CPU
Intel Core 2 Duo E6600 Conroe 1066MHz FSB 4M shared L2 Cache LGA 775 Processor
http://www.newegg.com/Product/Product.asp?Item=N82E16819115003
Motherboard
Not sure.
Memory
Corsair Value Select Dual Channel 2048MB PC3200 DDR 400MHz Memory (2 x 1024MB)
http://www.newegg.com/Product/Product.asp?Item=N82E16820145579
Video Card
ATI Radeon X1900 XT / 512MB GDDR3 / PCI Express / Dual DVI / VIVO / Video Card
http://www.newegg.com/Product/Product.asp?Item=N82E16814195002
OS Hard Drive
Western Digital Raptor WD740GD 74GB 10,000 RPM 8MB Cache Serial ATA150 Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?Item=N82E16822144160
Storage Hard Drive
Seagate Barracuda 7200.9 SATA NCQ 3.0Gb/s 300GB 16MB Cache (OEM)
http://www.newegg.com/Product/Product.asp?Item=N82E16822148110
Here's my build:
CPU
Motherboard
Not sure.
Memory
Video Card
OS Hard Drive
Storage Hard Drive
