I've just bought the basic components for the first computer I've ever built and while I'm still waiting for the E6600, I was checking the other components and I read in the specs for the BFG 7900GTX that it needs a 12v power line that will supply 26 amps.
I was going to buy an Antec 550 watt unit that was supposed to be ATX 2.2 compliant. They were out of that unit and the guy there, (at Fry's), suggested an Antec 500 watt unit and assured me that it will work.
Reading the specs in the book that came with it, says that it supplies 19 amps on the +12v line and I believe it says that it will supply 12 amps on the -12 volt line. (I don't have it in front of me at the moment.) I'm not sure what that means. Will it work with the 7900GTX?
I also found that this unit isn't listed as ATX 2.2 compliant
Do I need to take this unit back and exchange it or will it work reliably?
Thanks for any help provided!
