G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
I have our dns setup with dynamic dns enabled so each dhcp client gets a
record created on startup. The problem I'm seeing is my primary dns will
frequently return a not found error and then if you simply redo the query it
returns the correct results. You can redo the same error within 1 second and
what it could not find it can suddenly return accuratly.
I have webtrends monitoring the dns servers to see if they go down. Every 2
to 15 minutes the server becomes unreachable and then re-appears to the
monitoring software. We've had other software monitoring and it to found
that the primary dns would vanish and come back.
Any pointers on where to look for this?
