Hello everyone. This is my first post although I have been lurking for a while. I have a couple of questions for you guys. This will be my first build... yes I jumped on the conroe bandwagon My set up is as follows:
core 2 duo 6600
Hiper 580W PSU
Thermaltake Armor Jr
Corsair xms2 5400c4 2x1 Gig
sapphire x850xt
2 x seagate 320 gig non-raid one for os other for storage
Ati silencer 5 for gpu
Abit ab9 pro
From my research here and on other sites I have learned that running stress tests on home build are a good idea immediately after build. I plan on running dual prime 95's in order to tax both cores. I don't plan on OC'ing and will be using the system for photo and occasional video editing, AutoCAD, and multi-tasking. How long do I need to run prime 95? Is overnight enough or 12 hrs or more? Also should I attach the ATI silencer before or after? If for some reason the gpu fails, would I run into problems RMA'ing if have removed and replaced the stock cooler? (I plan on using AS 5 which I guess I will have to remove if I have to put the stock cooler on for RMA). Thanks in advance for the help. Please drop any other info that my be helpful for my first build. Thanks
core 2 duo 6600
Hiper 580W PSU
sapphire x850xt
Abit ab9 pro
