DNS Fowarder is greyed out
Last response: in Windows 2000/NT
September 29, 2004 10:03:22 AM
Archived from groups: microsoft.public.win2000.dns (More info?)
I am trying to configure the DNS fowarder but it is greyed
out. How do i change this so i can edit it??
Thanks
greg
More about : dns fowarder greyed
Anonymous
September 29, 2004 12:07:18 PM
In news:381e01c4a624$b2c86ed0$a501280a@phx.gbl,
greg <anonymous@discussions.microsoft.com> commented
Then Kevin replied below:
Open Forward Lookup Zones, delete the "." zone, refresh the DNS console,
then you can add your forwarder. BTW, deleting this zone enables root hints,
so it will begin resolving external names without a forwarder.
Best regards,
Kevin D4 Dad Goodknecht Sr. [MVP]
Hope This Helps
When responding to posts, please "Reply to Group"
via your newsreader so that others may learn and
benefit from your issue, to respond directly to
me remove the nospam. from my email address.
http://www.lonestaramerica.com/
Use Outlook Express?... Get OE_Quotefix:
It will strip signature out and more
http://home.in.tum.de/~jain/software/oe-quotefix/
Keep a back up of your OE settings and folders
with OEBackup:
http://www.oehelp.com/OEBackup/Default.aspx
September 29, 2004 12:07:19 PM
Thanks,
that worked out fine.
Currently we are using a DLINK Router as a DHCP server
(192.168.x.x) I was reading a post saying that this is
not recommended. How do i configure the DHCP service on
the Windows 2000 Server to handout these IP addresses??
>-----Original Message-----
greyed
the DNS console,
enables root hints,
forwarder.
>Best regards,
>Hope This Helps
>with OEBackup:
Anonymous
September 29, 2004 1:17:56 PM
In news:0a4101c4a626$bc27a7a0$a401280a@phx.gbl,
> Thanks,
Using the DHCP management console, you simply click new scope, this starts a
wizard that sets up commonly used scope options like DNS addresses, DNS
domain name, WINS server and node type. Then authorize it in Active
Directory and it is ready to go.
Best regards,
Hope This Helps
with OEBackup:
Anonymous
September 29, 2004 3:42:01 PM
>> Thanks,
> starts a wizard that sets up commonly used scope options like DNS
> addresses, DNS domain name, WINS server and node type. Then authorize
> it in Active Directory and it is ready to go
....pardon my jumping in....
Then disable the DHCP server on the router. And run ipconfig /release
..../renew on all workstations if you're using a scope that overlaps whatever
the DLink is doing now.
Also, I suggest setting up the DHCP scope on the server from xxx.xxx.xxx.1 -
..254, and make exclusions in it - such as, exclude .1 - .100, and .200 -
..254 (or somesuch). This will make it easier to change your scope later. Use
..1 - .100 for statics (server, router, printers, etc.).
