Hello all,
I recently built the following PC. The specs are as follows:
Asus AM2 M2N-E motherboard
Corsair XMS2 6400 1GB Cas 5 ram
AM2 X2 4600+ processor
250GB Sata 2 Western Digital 16MB Cache Hard drive
530W Hiper Type R Modular PSU
Sapphire 256MB X1300 graphics card
Antec Super Lanboy Case
Zalman CNPS9500 AM2 Heatsink/Fan
Windows XP SP2 Professional
However, I am experiencing constant freezing and some rebooting as well as the problems:
1) When I, say, delete a folder, the folder would still be on my desktop until I right click and select refresh?
2) When I "switch" user to log in as another user, my screen would go black until I physically switch my monitor off and then on ??
3)The PC would sometimes freeze and automatically rebbot itself ??
Now for my cooling problems:
With a bog standard AMD heatsink/fan (no fancy pipes) my idle cpu temp is 40 degrees and on full load its 60 degrees. I purchased the Zalman cooler and expected amazing temperature drops but they are the same!? I cheched the bios to check the cpu temp (in case the Asus software was screwy) but the bios told me the same???? P.S My case has 2x 120mm fans and my PSU has one 120mm fan and one 80mm fan.
In conlcusion, I think I my have a faulty motherboard or even a bad PSU? What do you guys and gals think? Please provide me with any info you possibly can, as well as any experiences with the Zalman cpu coolers for AM2 as I had expected big temp drops.
Thank You all for your time and feedback.
