Does anybody know if an Power & Cooling 1KW PSU will fit in the Lian Li PC-V1200 case. The PSU is 23 cm deep and by the looks of it it will fit since this case is an extended version. But does anybody know for sure???
Well I want a 1 KW PSU so I can use it on the 4x4 system when is comes out. But i,m not really sure how much power that system is going to use so I figure i,d be prepared. But i,m not sure yet since $500 dollar is really really steep.
Yes I think that is what i,m going to do. i,m going to do a final upgrade on my current system and wait till 4x4 has been released and all the bugs have been fixed.
I,ll just add 2gb of ram and get the X1950XTX when it comes out.
Just an FYI, Enermax also has a 1kw psu out called the Galaxy. I know that it doesn't have quite the reputation as PC P&C but they are considered one of the better makers. It's also significantly cheaper...
It seems like you're not really loading that PC so I'd go with a Silencer 750... it's smaller... and it's $200. That and 750 watts should be ample power for you.
