Archived from groups: comp.dcom.lans.ethernet (More info?)
Hello:
I recently had a power surge take out my router (linksys BEFSR41 v2
Firmware Version 1.46) i was able to repair it, everything seems to
work fine, but on power-up all leds light except the Act on the WAN
column, i can't remember if it was like that before the surge.
Could someone be so kind as to unplug and plug his/her unit and see if
it behaves like mine?
In article <e726e217.0408281839.53a0ffb3@posting.google.com>, Steve Sousa
says...
I have a Linksys BEFSR11; so old that there is no 'v' number on the label.
On power up, all the lights will flash; WAN 'Act' and 'Diag' lights briefly
red, all others green. After the boot sequence completes, it settles down
with just the WAN 'Link' light lit, and occasional flashes of the WAN 'Act'
light in response to LAN traffic from the Netgear. There is currently no
device attached to the LAN port.
Norman
~Win dain a lotica, En vai tu ri, Si lo ta
~Fin dein a loluca, En dragu a sei lain
~Vi fa-ru les shutai am, En riga-lint
NormanM <spammail@blackhole.invalid> wrote in message news:<MPG.1b9dcbcfccbbec3a989732@news.sf.sbcglobal.net>...
In article <e726e217.0408311705.7f9c5556@posting.google.com>, Steve Sousa
says...
> Thank you for your answer.
You are welcome. I am currently trying to decide what to do with it. I had
an older, flaky firmware revision; but it seems to be stable since bringing
the firmware current.
Norman
> Yes, all lights temporarily illuminated at power up is
normal,
I believe this indicates a self-test is being run. I have a
question for you about "i was able to repair it" HOW? I
think
mine (linksys BEFSR41 v2 Firmware Version 1.46) received a
power surge as well. Now whenever I plug in a lan cable, I
get all LEDs on that channel blinking rapidly or solid -
Link/Act, Full/Col and 100 respectively. Can not seem to
communicate with router - ping, tftp, etc..... Any ideas?
Any help, suggestion would be greatly appreciated!
Best Regards,
Andrew R. (Willy's NOT my real name.... ;/ )
> Hello:
> BEFSR41 v2 Firmware Version 1.46) i was able to repair it,
> everything seems to work fine, but on power-up all leds
> light except the Act on the WAN column, i can't remember
> if it was like that before the surge. Could someone be so
> kind as to unplug and plug his/her unit and see if it
> behaves like mine?
> Thanks in advance.
> Steve Sousa
