Tom's Hardware Forums » Homebuilt Systems » General Homebuilt » E6600 system running sluggish
Add a reply
 Word :   Username :
Bottom
Author
 Thread : E6600 system running sluggish
Profile: enthusiast
More Information
Got my whole system up and running:
E6600
Asus P5W Dh Deluxe
2GB OCZ Rev2 DDRII-800
HIS X1900XT
but for some reason things run like crap once in a while. Like i will clikc to open an excel file (office 2007 beta) and the system will just sit there (task manager shows 0 cpu usage) for like 15 seconds and then suddenly the computer will finaly decide to open up excel. It also happens sometimes when shutting down or little things like locing the taskbar.
Any idea where these probs are coming from?
Related Pr oduct
Profile: enthusiast
More Information
the only laggy prog i have is Alcohol 120% but it does it on my other puter also apart from that nuffin, in fact it dosnt do it in 64bit xp
Profile: enthusiast
More Information
Have you installed up to date chipset drivers? have you tweaked the OS settings (like page file size, etc.)?
Unless you have done any weird BIOS tweaks I'd strongly suspect you're not having a hardware problem but rather a driver problem.
I personally pwn you
Profile: addict
More Information
so even though hehas 2gb of ram he would still need to make a big paging file ? like 4.5gb? :oops: wow
Lord of the Duck Clan
Profile: Faithful Poster
More Information
Quote :
Yep. Virtual memory is used in a modern OS even with massive amounts of RAM installed.
Profile: journeyman
More Information
And if your running raid those drivers need to be installed as well.
Profile: enthusiast
More Information
Not running RAID and my virtual memory is set for 4GB yet still the system hangs when doing some things. Like if i double click to open somethign it sits for 15 seconds (if i hit cntrl alt del it shows no process using the cpu so its like like the cpu is busy)
any other possible reasons or will i just have to try a reformat?
Profile: nimble knuckle
More Information
there have been issues between OCZ DDR2 ram and Asus motherboards so that could be causing the problems...
Profile: old hand
More Information
> office 2007 beta
Could be that.
Pauses with no CPU use can occur when Windows is looking for a network resource that isn't available anymore.
Profile: enthusiast
More Information
there is no actual failure. it just takes a good 15-30 seconds for the computer to even start opening the file (no, there is no cpu usage during that time)
Profile: enthusiast
More Information
Is there a possibility it is a problem with any of my hardware? I would have thought if it were the memory, cpu or motherboard the problem would be in every action i did (cause firefox and aim and stuff opens right away just some things take a crap load of time to start opening)
Profile: enthusiast
More Information
I agree, I would make sure that al drivers are up to date for every component and software program.
Profile: stranger
More Information
man i am having the same type of problem,, the comp doesnt seem to have the "umph" i was expecting, gettin long boot up time and some programs take longer then expected time open up etc... like i had a few poker open before and my mouse started to lag... im not sure if its something to do with my config or what... i mean it shouldnt be doin this, at least not feel so "ordinary" lol. i know its good because i ran battle field 2 on it and it was amazing on fullly cranked up GFX and felt veery responsive, but general multi taskin is leaving me a bit unimpressed... i think i will have to go on a manhunt for some drivers and updates i thk (although performed win update)
Let me know if u find some kind of fix..
Profile: enthusiast
More Information
something is just with with ur setupsd mine boots in no time at all so much faster hen my old p4
Profile: enthusiast
More Information
So i uninstalled mcaffee virus scan and the problem seems to have gone away. god i hate virus software. Thanks for all the advice though guys
Profile: newbie
More Information
Stay away from the home editions of McAffee and Norton. They willl suck your system dry. Nod32 and AVG(its free) are good alternatives and im sure there are a couple more as well.
Sorry the comment i made below is incorrect, as i found out after some research.
BTW you shouldnt need a large pagefile with 2GB of ram, infact setting a large value will prompt your system to use it more than it should.
Profile: newbie
More Information
I can vouch for AVG free. Also page file size depends on what you do with your pc.. If you use a lot of memory intensive apps then you will need a large ish page file
Add a reply
Google Ads
