Archived from groups: microsoft.public.win2000.dns (More info?)
Hi and thanks in advance for any help.
I have a new and very small 2003 Active Directory setup. I'm using one of
my servers as a place to store files but at sometime in the future the
location of this store may change.
A programmer is writing some ASP to access this share and so, because it
might change, I setup a CNAME in DNS so that points to the machine so that in
the future if the data moves I can simply change where the CNAME alias points.
The problem is this: it doesn't work
if I try to connect to
\\machinename\share then I can connect
\\cname\share then I'm told that "You were not connected because a duplicate
name exists on the network. Go to System in Control Panel to change the
cumputer name and try again."
I'm puzzled by this. What I'm trying to do seems pretty straight forward
and I'm suprised that a CNAME isn't working for me.
Does anybody have any idea what I doing wrong and what work arounds I can try?
Thanks.
Thanks.
