Archived from groups: comp.dcom.lans.ethernet (More info?)
"Il sindaco" <majestic_23@libero.it> wrote in message
news:Ka35d.7162$H11.193186@twister1.libero.it...
> What happen if i take a switch over satellite to do a satellite -lan? What
> are th problems?
A satellite lan? Can you be more specific?
If you mean you are trying to create a lan and have all computers on it
access internet via satellite, then its doable.
If the satellite uses ethernet, then you can get a cable/dsl router to share
the internet connection.
If it uses USB, which is what Directway used last time I checked (3 years
ago) then you will need one computer on the lan with 2 NICs and setup
Internet Connection Sharing(if using Windows).
The only problems I see, ......satellite internet stinks. Its an ok
concept, but the latency will have you pulling your hair out. Dial-up is
almost better, but not for downloads.
