I've done a fair bit of research over the past couple of weeks on what I need, so would be really grateful if anyone could give me a warm fluffy feeling that the spec I've gone for is sensible.
I've read that the build needs to match the requirements; so a bit of background as to what I'm looking for. I currently have a P4 3.0ghz on an old ASUS AGP board (2gb ram) that I am going to convert to a windows media centre PC. This will be used for listening / watching music, film (hooked,for now, via vga to a HDTV)- nothing too streneous.
This allows me to get a new 'main computer'. 80% of the requirement here is for gaming (cant wait to play Oblivion on a decent machine), although it will also be used for film decrytion, data processing (sql, excel, access) and general use.
The monitor I will be using is a 19in Samsung LCD (1280x1024), and I cant see this being upgraded within the next couple of years.
Ideally I want something that is future proofed as far as is currently possible- but I dont want to wait 6 months for the 'next' technology. The budget is only constrained in terms of value for money (rather than cheapest).
Ive built 2 pc's before- but not overclocking much (something Im keen to try more with my next rig).
So my build so far is as follows (I've tried to provide a little reasoning);
ASUS P5W DH Deluxe SKT 775 dual-core Core2Duo Conroe ready Crossfire 8channel audio ATX
Ruled out the DS3 because of oc potential & cpu choice; only £50 difference between this and DS3, so is not something worth skrimping on?
Intel Core 2 Duo E6600
Again, the pricing helps define this choice; I wanted the best cpu I could get affordably; £50 diff btwn 6400 & 6600- £170 between 6600 - 6700.
Sapphire Radeon X1900 XT 512MB GDDR3 Dual DVI / ViVO PCI-E
I changed my mind on this at least half a dozen times; originally wanted a Nvidia board- but Ive gone for this again on price (£220); performance (what Ive read seems to suggest this is the best performing board for this price bracket) and also brand (had Sapphire before and was really pleased). Im also looking at oc potential. Aware of noise / heat issues, so planning to fit gpu cooler.
Corsair XMS2 2GB (2 x 1GB) DDR2-800
Gonna have issues sourcing this in the UK- but from what Ive read many of the other brands have issues. Again, 800mhz bought for oc potential.
Antec NEO HE550GB 550W Modular PSU With 80mm Low Speed/noise Fan 18db
I have a feeling 550w is overkill for the job; but I dont know how much overkill...
Other stuff; only use on board sound (only got 2.1 speakers anyhow); old case
Coolermaster Wavemaster; floppy, cd & dvd drives; 2 hard disks; ethernet connection to router; 4-6 usb devices at any time.
The other questions Im unsure of are;
a) is it a mistake not getting an sli board
b) is the spec complete overkill for the monitor its running on
c) can I make it more 'future-proof' without spending significantly more
c) what have I missed?
If youve got to the end of this post- thanks for reading this far! Any help / mockery / trolling will be gratefully received
