G
Guest
Guest
Archived from groups: microsoft.public.win2000.dns (More info?)
(Sorry if wrong NG)
Does anyone know what is going wrong with the PC below. Notice how all pings
are 'resolved' to "°ÿ" and names cannot be resolved. This is only a problem
on 1 PC (i.e. the server is ok for other PCs).
I've tried removing and reinstalling the network card on the PC (winXP pro)
to clear the tcp/ip settings to no avail.
Any help appreciated!
-H
D:\Documents and Settings\Barry Evans>ping www.google.co.uk
Ping request could not find host www.google.co.uk. Please check the name and
try
again.
D:\Documents and Settings\Barry Evans>ping 216.239.53.99
Pinging °ÿ with 32 bytes of data:
Reply from 216.239.53.99: bytes=32 time=421ms TTL=238
Reply from 216.239.53.99: bytes=32 time=239ms TTL=238
Reply from 216.239.53.99: bytes=32 time=264ms TTL=238
Reply from 216.239.53.99: bytes=32 time=287ms TTL=238
Ping statistics for :
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 239ms, Maximum = 421ms, Average = 302ms
D:\Documents and Settings\Barry Evans>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : barry
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection 3:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : D-Link AirPlus XtremeG+
DWL-G520+ Wi
reless PCI Adapter
Physical Address. . . . . . . . . : 00-0F-3D-56-E3-B7
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.111
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
158.152.1.58
(Sorry if wrong NG)
-H
try
again.
DWL-G520+ Wi
reless PCI Adapter
158.152.1.58
