Weird problem with new X850XT
I just got my Sapphire X850XT earlier today and installed it, along with a fresh install on a new HD.
I used the software that came with the card, and then updated with ones from ATI's site. But sometimes, these spots... like, the inverted color, appear on my screen. It starts with a few here and there and usually they disappear if I refresh my desktop. But with time, more and more build it and they start to disappear/reappear randomly.
Any ideas as to what to do? This didn't happen with my PowerColor X800GTO but I'm really hoping it's not my monitor.
More wierdness
Since I can't try this any games yet because Steam takes so long to update and what not, I ran 3DMark 05 demo and during all the demos, there were these breakups everywhere. Not sure what they're called but it's like whole polygons go missing and instead I see empty black spots.
I installed ATI tool just now and saw that just after that slight use, the temps were at 44C! Sapphire's default settings have the fans at 5% unless the card runs at like above 98C. WTF? Anyway, I adjusted it be on full blast at all times but this things loud... hopefully it'll solve the issues though.
More wierdness
More about : weird problem x850xt
Nope, it was indeed at 5%. It seems that's what it is for most people according to the reviews posted at Newegg.
Anyway, adjusting the fan speed at max helped get rid of the artifacts (guess that's what they're called).
With the default 5% fan speed, the card runs at 44C at idle and hit a blazing 84C before freezing and shutting down HL2. I don't know what Sapphire was thinking.
Luckily for ATItool allowing me to have variable fan speeds. I have to keep it at 50% to keep idle below 40C and a full blast for any task requiring the graphics card. This card is freakin' loud and very hot... and amazingly enough, some people have actually OCed it! 8O
Related ressources
- Problem with ATI Radeon X850XT 256mb Video Card PCIe - Forum
- ATI HD4670 512MB vs. x850xt 256mb - Forum
- X850Xt running at 100c with no overclocking........... - Forum
- Just installed X850XT PE and WOW!! - Forum
- Big problems with new X850XT , need any help I can get - Forum
It averages around 58C at full load with 100% fan speed.
But the problems start very early... check these images out.
http://i11.photobucket.com/albums/a187/fyreboltx/sappx8...
http://i11.photobucket.com/albums/a187/fyreboltx/sappx8... - No, this isn't the side of a cliff.
http://i11.photobucket.com/albums/a187/fyreboltx/sappx8... - It's a lot worse than it looks.
Note that the temps go down because I had to pause and minimize the game to save the pics, allowing for the GPU to go down.
This is my card, BTW: http://www.newegg.com/Product/Product.asp?Item=N82E1681...
Quote:
It averages around 58C at full load with 100% fan speed. But the problems start very early... check these images out.
There must be something wrong with the card; 58C is a normal temperature for a grahpics card. I'd RMA it to newegg; they're very good with that kind of stuff.
newegg can't have quality control over products because there is no way to test everything. How do you expect them to know products are bad? That's why they have the fast and reliable RMA service because they know they sell products that are rushed out (video cards).
I think a lot of problems stem from improper PSUs myself.
Mine was exactly the same, from powercooler, sent it back the other day. They are checking it this weekend and sending me a new one when tis checked. Mine got so bad in the end it would do it on the desktop aswell. Will keep u informed what my new one is like.
http://i61.photobucket.com/albums/h52/CallumNLaw/deskto...
http://i61.photobucket.com/albums/h52/CallumNLaw/Unreal...
http://i61.photobucket.com/albums/h52/CallumNLaw/Quake4...
http://i61.photobucket.com/albums/h52/CallumNLaw/AOE3.j...
http://i61.photobucket.com/albums/h52/CallumNLaw/Whatth...
Um... ok, now I'm completely lost.
I moved back to college and my computer came with me, faulty GPU and all. And when I tried to start it, it wouldn't power on. I couldn't figure out why but it worked after I resteated the memory.
Then, being bored.. I decided to try Half Life hoping that I could play it without those artifacts. Luckily it worked just fine. Then I went to check on the card temps a saw that it was at 45C. So I tried some of my graphics heavy games. The temps shot up but the artifacts never appeared.
I'm glad it works but I'm also confused as to why it is working. Could just have been due to the memory?
Quote:
I have a 1 year old X850XTPE made by ATI. The fan is also stuck at 5% till around 90degrees
You could try updating drivers, I had artifacts in Flightsimulator with old drivers, then new ones fixed it. If that dosn't work, I'd RMA, in Oblivion mine gets to 92 degrees and it runs fine :wink:
How's that X850XT working for you in FS2004? Are you going to upgrade for FSX?
Glad it works..... That actually happened to my friend, I never beleived him though untill you
It runs fs2004 awsomely, 100% maxed out! here are some pics that I took
I have the fsX demo, and it runs very good! heres fsX demo review and pics.
That's awesome! Are you a beta-tester? How'd you get the demo? I'm glad to see that I have a few more options if I want to go the inexpensive route for a good video card for the next 6 months or so. How important is your CPU for FSX? Do you think an X2 3800 will run it well?
How will a card that runs SM 2.0 run on a game that runs SM 3.0? Does anyone know?
Quote:
i have my core overclocked at 580, which is decent for an x850xt, at 585 i start to get artifacts, and that is with the stock fan, and how did you change the fan speed, i guess i have an old version of ATI Tool and not the new oneYou can't really check the fan speed, at least I don't think so. All you can do is change the percentage of the max fan speed that's being used.
Like, Sapphire set the fan speed to 5% of the max as long as temps remain under 98C. ATITool lets you change the fan speeds to different temps or keep the fan/GPU temp at a fixed speed.
Go to settings (on the bottom right), and then select Fan Control on the pull down box.
Quote:
I just ordered a SAPPHIRE X850XT (on its way) and I'm hoping that I don't run into any of these problems.How important is it for this card to get is own power (not shared with anything else)?
It seems to be a rare case as I didn't see too many of these cards showcase the problem. But there are 4 different types of X850XTs from Sapphire and they're all similar in specs I think.
Hehe
The demo is availible here.I have a Pentium 4 650, and it runs the game very well. Processor is definatly more important than video card in fsX, so a X2 3800+ will run the game very well. The game dosn't utilize two cores very well, but it does. Core 1 (logical) was at 100% while Core 2 (logical) was at 50%.
In fsX the terrain engine is dependant on the CPU, with a slow one with terrain won't load properly and will look bad. Not much VRAM also stops the terrain from looking good
Related ressources:
- ForumDoom 3 and ATI X850XT "flame" problem
- ForumRadeon X850XT problem
- Forumno display with new rig - x850xt
- ForumNew ATI X850XT AGP
- ForumProblem with X850XT
- Forumx850xt pe 512mb ?
- Forumx850xt stops working after windows update
- Forumx850xt problems
- ForumCCC install/uninstall pbs + Weird screen colour
- ForumSapphire Radeon X850XT green bars when capturing
- ForumRadeon x850xt in an optiplex gx270
- ForumX850XT to 1900GT or 7900GS. Not worth it?
- ForumLow 3dmark05 score with x850xt pe
- ForumIs a x850xt pe still a good card?
- ForumPlease help me choosing a GFX Card
- More resources
