Are modular cable psu's a good idea and relialbe or a source of trouble because of the additional plugs at the psu?
Are these plugs/connectors standardized so that if I start off with a 600 watt for instance today I could add an 800 watt in a year and use existing cables without rewiring the whole system?
This concern arises around wiring up an Antec P180B case which requires longer then "normal" cable lengths I read.
Thank you.
Thank you.
