Alright, i had a Old desktop computer with a p4 2.4gh, that crapped out on me. i want to use as many as the old parts as possible.
i have a 120gb IDE hdd, 350 antec psu, dvd drive, cdrw drive, floppy drive, 80mm fan, (2)256mb pc2100 ddr memory.
I plan on spending 300 dollars or less to get it running and started. And then Add my old graphics card, later on.
so here is what ive chosen so far.
http://www.newegg.com/Product/Product.asp?Item=N82E16811156018
http://www.newegg.com/Product/Product.asp?Item=N82E16827152058
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1559988&CatId=2017
http://www.directron.com/winkitblue.html#caption
i plan on having (3) 80mm fans running, with a cheapo fan controller from compusa, all blue led, I plan on buying 2 of those light kits, because good deal on Round IDE cables, and 80mm led fans. and the cold cathode light.
the Motherboard, supports all my old stuff, and with the PCIe slot, it can use my graphics card, once im done with it in my main rig. I might have to purchase a new power supply as my Antec Smartpower is only 20 pin, and 350watt is not enough for a PCIE card.
tell me what you guys think, i probably am just going to use this as a fun computer, in the basement, and i have a TV tuner card that i can put into it to make it into a tivo. As for CPU, im gonna wait till the prices go down all the way on socket 939's.
The lowest i'll go is a amd 3700+ but im waiting to see if prices go down further so i can possibly pay a little more for something much better.
