Archived from groups: microsoft.public.win2000.dns (
More info?)
> I have set up Active Directory many times in larger environments, but
there
> was always a DNS server at each location. This is my first time
attempting
> to resolve DNS over a VPN. I appreciate your time and effort.
Is there any practical way to make a Secondary DNS
server at the remote site?
On the router? On one of the clients? (You cannot
run MS DNS on a Workstation but BIND will run on
a reliable workstation if you can keep it on.)
Notice that if the LONG time-outs don't work then you
probably don't have a time problem and this is getting
blocked SOMEWHERE.
Herb Martin
"adamofevil" <adamofevil@nospam.optonline.net> wrote in message
news:Xns963D670C9526Fadamofevil@207.46.248.16...
> "Herb Martin" <news@LearnQuick.com> wrote in
> news:OodBCbLRFHA.3788@tk2msftngp13.phx.gbl:
> > news:Xns963D15EB26918adamofevil@207.46.248.16...
> >> >> DNS: Single AD integrated zone lenderservices.local (no . zone)
> >> >> Configured for forwarding to ISP DNS servers
> >> >> Location #1 contains the server, subnet 192.168.168.0/24
> >> >> Location #2 contains no server, subnet 192.168.0.0/24
> >> >> Location #1 & 2 are connected via a gateway-gateway VPN
> >> > May we presume the VPN routes in general and is unfiltered?
> >> > Ping, telnet server 80, etc.?
> >> Yes. Ping, telnet, RDP and everything else under the sun seems to
> >> work fine through the VPN.
> >> >> Clients at location #2 are configured with static addresses
> >> >> pointing DNS
> >> > to
> >> >> 192.168.168.2
> >> > So they must get DNS requests fulfilled across the WAN/VPN?
> >> > Not illegal but slow probably.
> >> Well there are only 4 workstations at location #2, so I didn't see
> >> the need to recommend another server at that location.
> > That makes sense, especially if there are no DCs nor
> > resource servers local.
> > What sort of box is the router on the remote end?
> > (Maybe a secondary or caching only DNS server
> > there will help to cut down on such problem but this
> > is not likely your real problem.)
> Both ends are using 10Mb/1Mb cable modem with a gateway<->gateway VPN
using
> Netgear FVS318 routers. What is unusual is that I had them buy two of the
> same brand & model router for the VPN but one of them is v1 and the other
> is v3. The v3 seems a bit more configurable with the VPN settings,
> especially when it comes to encryption, but this didn't seem to pose any
> problems for me. I was able to get the VPN up and running very quickly and
> as previously noted there does not seem to be any firewall issues (all
> workstation Windows Firewall's are disabled through group policy, which I
> verified on each local workstation, and the server Windows Firewall is
also
> disabled, as the router is fully capable of acting as the firewall) as I
am
> able to communicate through any desired port (even if I telnet to the
> server on port 53 I receive a blank screen which I believe is indicative
of
> a response). At first I thought maybe there was too much encryption on
the
> VPN so I lowered it from 3DES to DES, but that did not solve the problem.
> >> They should still be
> >> able to get DNS over the WAN though, and it just doesn't seem to work
> >> properly.
> > Yes. That is correct. And within a reasonable
> > delay it will work that way.
> >> >> Clients at location #2 are able to resolve hostnames but not FQDN
> >> >> names
> >> > This sounds like they are using broadcasts to resolve the simple
> >> > computer names through NetBIOS and failing to resolve DNS
> >> > names with suffixes (FQDN means something different that you
> >> > believe).
> >> > What about the computer DNS names in the System Control panel?
> >> > Are they named fully? (Not just "computer" but
> >> > "computer.domain.com"?) They need to be.
> >> They are all computer.lenderservices.local
> > In the System control panel?
> Yes
> >> >> Clients at location #2 are unable to resolve the majority of
> >> >> external DNS requests
> >> > What does the following give:
> >> > nslookup DC_NAME.lenderservices.local
> >> > (Copy and paste the full answer and request, do not type it, and
> >> > please don't use pictures of the screen.)
> >> C:\Documents and Settings\abrass>nslookup server.lenderservices.local
> >> DNS request timed out.
> >> timeout was 2 seconds.
> >> *** Can't find server name for address 192.168.168.2: Timed out
> >> *** Default servers are not available
> >> Server: UnKnown
> >> Address: 192.168.168.2
> >> *** Request to UnKnown timed-out
> > I should have asked you to try to following;
> > (We could have saved a message round):
> > nslookup -time=10 server.lenderservices.local
> > nslookup -time=20 server.lenderservices.local
> > If the long timeout works then we have a time problem,
> > but if it fails we (likely) have a true connectivity or firewall
> > problem.
> > Also try the same settings with the INTERNAL DNS server
> > specified using IP address as the DNS Server:
> > nslookup -time=20 server.lenderservices.local DNS.SRV.IP.ADDR
> From the internal server the responses are all normal and all lookups are
> successful. It is only from workstations on the other side of the VPN
that
> have this problem. I will try the other 2 commands later this evening and
> let you know the results.
> >> > Clients must NOT use multiple DNS servers that do not
> >> > return the same answer, so your temporary solution is
> >> > going to cause trouble even if you fix the real problem.
> >> Well I needed to get them able to surf the internet until I find a
> >> way to solve this problem. I know exactly what you mean though, and
> >> I wish for this to work properly rather than "jimmy rig" it.
> > Understood -- just note this is NOT suitable once
> > the problem is resolved.
> I am fully aware of this.
> > And you CANNOT use both the "correct" server and
> > this external resolving server on the client NIC settings,
> > and expect reliable results.
> I agree with you wholeheartedly, which is why I am trying to figure out
why
> my original configuration does not work.
> > Many people try to put both servers one the NIC thinking
> > both will be used, or thinking the first will always be
> > used if available -- this is not true. The first will be
> > preferred but not reliably used. The second will never
> > be used if the first answers.
there
attempting
